Question about Siemens HF36V305 1000 Watts Microwave Oven
My Siemens microwave gives error code 7, please help !!!!
Siemens microwave - model HF23056 - stops after 22 sec no matter the power level or time set & read this could mean controller has detected a problem with inverter or bad magnetron? Any experience?
The symptoms are consistent with a defective inverter board or magnetron. If you're lucky, it may give you a fault code that you can look up.
Jan 29, 2017 | Siemens Microwave Ovens
Code for samsung microwave
Can you please clarify what the main problem is so we can give you exact solution? I'm sorry I didn't quite understand what you mean. Thanks!
Oct 10, 2008 | Microwave Ovens
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Why does my siemens microwave cut off after a few seconds
The magnetron, "heart of the microwave", the inverter board, "7 years old or less" and possibily the keypad control board.
Apr 20, 2012 | Siemens Microwave Ovens
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Error coes 7
That loose cable sounds like it would be the humidity sensor. They're usually a shielded cable with three pins.
It will usually plug in close to a large resistor, like on the Sharp shown below.
Probably on the upper (display / control) board but I won't wears to that.
If you don't find it, please post a few photos of your board.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 07, 2008 | Whirlpool GH9177XLB Microwave Oven
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
I'm not finding that error code.
Does it come on 2 minutes after you plug it in?
If so, it may be a failing keypad or door switch / mount.
Of two minutes after you have been cooking?
That may indicate a bad humidity or other sensor.
Please give more detials so we can help further.
Oct 21, 2007 | Microwave Ovens
Siemens HF36V305 1000 Watts Microwave Oven Logo
87 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
