Question about Gigabyte GA-8I915P Duo Pro Motherboard
Cannot get liteon dvd to connect to system HAVE TRIED ALL I KNOW including drive detective to no avail .need help
  • Gigabyte Master
  • 27,725 Answers
make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 04, 2011
Can not Find in "My Computer" the DVD RW and DVD
Are the power and data cables plugged in from the DVD-RW to the PC?
If cables are plugged in ans secure, download the driver and install it on your PC. You might need to restart after that.
http://www.liteonit.com/DOWNLOADS/ODD/SOHW-1673S/firmware/JS0DN.exe
Mar 04, 2011 | Lite On DVD+/-RW LITEON SOHW-1673S BLK RT...
The liteon dvdrw will not burn a DVD
Perhaps you should reinstall the Sonic stuff, in case it was affected since the virus cleanup.  If the OS had some of its components quarantined from virus contamination, you are probably stuck reinstalling the OS...though of course you can search the web (and not least Microsoft.com if that's the sort of OS you use) for healing 'media detection' issues (w.r.t. your particular OS.)
Mar 18, 2010 | HP Pavilion a1610n PC Desktop
My DVD-ROM won't recognize DVD movies, but plays CD's perfectly well. I've downloaded 5 different players, to no avail.
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Nov 16, 2009 | Lite On LITEON 16X DVD BLACK OEM (Come...
Acer aspire one doesn't see liteon ez-dub
Linux operating systems may not support Liteon EZ-Dub External DVD Drive. Check on the Linux forums.
Jul 31, 2009 | Computers & Internet
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
2 SATA Drives will not burn DVD-R but will burn DVD+R
Well, for one thing, your system is faster then mine. AMD Athlon X2 4000+ 2.10 GHz, 2GB, BIOSTAR A770 A2+ 160GB SATA. Anyway, what sata port did you install these DVD-Burners to. I know it shouldn't matter, but humor me for a minute. I have mine on the last two normally. Seems to work fine. Try it and see.
Let me know
comier957
Aug 07, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Lvc9016g
I have successfully made hundreds of play-able DVDs from my home video using this Liteon LVC9016G. Overall I like this machine although it is very quirky.
First, I can tell you the only DVD that can work is SONY DVD+R 120min / 4.7GB. NOTHING ELSE WILL WORK RIGHT. I have used some DVD-R: You can record on it since everything appears to work. The got-ya is you cannot play it at all. I am sick of this because I have re-used some tape but ended up with useless DVDs! Take my word for it, I have tried many media like Maxwell or Verbatin. These "other brands" are fine on the computer but not on this machine. I don't know what this machine can detect and see the differences in the media.
The good thing is that I was able to connect the DV port from my camcorder (Sony mini DV) to the dv port on this unit. Cable was not included so I bought one very cheap from eBay. This connection gives the best control as the LiteOn remote control can control the recording from camcorder to the DVD recorder and even make different menu items. This is not a published feature but I figured out. As I said I have made hundreds of home video on this unit and it is very nice (when it works.)
Jun 06, 2008 | Lite On LVC-9016G DVD Recorder/VCR
USB Conect needs XP driver???
You really shouldn't need drivers for this drive in WinXP. I could be wrong on this one.
Check under device manager for DVD/CDROM drives. It should be listed once it is connected.
Mike
Jan 17, 2008 | Lite On SOHW-1673SX DVD±RW Dual Layer...
Liteon LVW-5045gDL+ dvd recorder will not burn to blank dvds
SAME HERE. I Have tryed a lens cleaner and seems to be working at the moment
Oct 09, 2007 | iLO DVDR04
Gigabyte GA-8I915P Duo Pro Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
