Question about Clarke Power Products Welding Tools
THE WIRE CONTINUOUSLY FEEDS THROUGH THE GUN EVEN WHEN IM NOT PRESSING THE TRIGGER. IT JUST KEEPS COMING OUT
    Scholar:
  • 133 Answers
The trigger engages a relay that starts the feeder motor. Make sure your trigger is not stuck. Listen for a "click" when you squeeze it. Next, take the side cover off and look at the motor relay. If needed, remove the motor wire from the relay and try it again. My guess is the relay has arched shut. Please let me know how this works out.
Roger
Posted on Apr 03, 2011
  • whelan43 Apr 05, 2011
    Thanks Roger, I will try it at the weekend, cheers Mike....
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
Why does wire keep coming out when trigger is not pulled
From the mig welder, unplug the trigger leads that exit the mig gun on the end of the gun that connects to the mig welder and power on your machine. If the wire flow stops, you have a shorted trigger circuit inside of the gun cable. If it doesn't stop wire flow, depending on your machine make & model, there is an internal issue with the trigger circuit that could possibly be just a simple relay issue.
Dec 25, 2014 | Welding Tools
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 | Garden
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Miller 350p welder gives a "help 3" code.
Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
To fix:
Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
Nov 17, 2010 | Miller Welding Tools
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
113 people viewed this question
Top Clarke Power Products Welding Tools Experts
Wade Mobley
Wade Mobley
Bill Boyd
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
