Question about Canon PIXMA MP130 All-In-One InkJet Printer
Printer problem LCD MESSAGE
At first I was getting the message to check the ink waste and then I got the message the ink waste tank is full and now it reads check printer 5600.
what does it mean and what do I do, toss it in the garbage or can I fix it?
  • Anonymous Aug 13, 2008
    I have changed the ink cartridges and now my printer says ck printer (5600). and I can't get to the menu.
  • 4,041 Answers
Hi There
How To Reset Waste Ink Canon Pixma MP130
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
At first I was getting the message to check the ink waste and then I got the message the ink waste tank is full and now it reads check printer 5600. what does it mean and what do I do, toss it in the...
Waste ink amount
EEPROM settings)
- At logic board replacement To set the waste ink amount to the
waste ink counter.
Perform in the
service mode.
Oct 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink tank nearly - message
it won't stop until the ink absorbers are replaced and the error reset in canon diagnostics. A shop repair, around $100.00
Jul 15, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset, Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Wast Ink Tank B!!!???
Sorry don't know that model here...:(
Feb 25, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
I have a check printer message on my canon imageclass mp390 which doesnt allow me to print. How do I get rid of this message. I originally had a waste tank full message but that has changed now to check...
Many times if you have changed an ink cartridge and there is as much as a smudge of ink where the cartridge makes electronic contact, the printer will send this check printer message. This check printer message will also appear on a lot of printers when the cartridge has been filled with bulk ink.
I hope this helps
Jun 01, 2008 | Office Equipment & Supplies
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
Canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Aug 03, 2007 | Cannon MULTIPASS C530 Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
276 people viewed this question
old marine
old marine
