Question about Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi Service Bulletin?
Do you have the link to this service bulletin? Does it have pictures?
-Thanks for the tips
  • rmjuarez1976 Oct 26, 2008
    I NEED TO KNOW WHAT TO DO ABOUT A DROPPED PIXEL
Here is the link. http://www.mitsubishi-tv.com/img/514730
it does not have pictures though.
Posted on Aug 08, 2008
Cruise control not engaging
More info needed. Does this vehicle have the 4 cylinder or 6 cylinder engine. FYI, there is a technical service bulletin [TSB 06-17-001] on how to diagnose this system. It corrects wrong information listed in the service manual with new info. See
http://www.mitsupartsworld.com/Eclipse%20TSB/tsb0617001.pdf
for info on this service bulletin.
Jul 25, 2014 | 2003 Mitsubishi Eclipse Spyder
What is the step by step process for shiming the valve liftersi have a 94 Magna with a lite lifter noise.
I had the same noise you are describing and recently found the solution. Honda has issued a Service Bulletin on the 1994 VF750C Magna regarding a knocking noise from the cylinder head areas. The noise varies as you tip the bike from side to side. It is likely caused by sideways thrust movement of the camshafts which then knock against their holders. The solution is to drill a small hole of precise diameter, length, and location, in each of the cam holders. This allows oil to seep into the space between the end of the camshaft and its holder to cushion the sideways thrust motion.
In the USA, this service bulletin is "VF750C #1". In Canada, this bulletin is "II-1-94", dated September 21, 1994. Your Honda dealer should have a copy of this bulletin.
Click here for an article that explains it in more detail and click here for an image that shows the hole location and depth. I performed this service myself and it fixed the problem! I hope this helps you.
Daniel Stewart
Oklahoma
Jul 09, 2010 | 1994 Honda VF 750 C Magna
Where is the 110 plug to heat the block
Hi
Thanks for using FixYa.If you are experiencing heating issues, then it is due to heater core issues. Ford 350 have these problems and it is also under recall due to this issue. Please see this wiring schematic of your 350 for details--
Please click on the link to zoom in. There is a Technical service bulletin available for this issue, you can view/download it from this link--
Technical service bulletin Heater core
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | Ford E-350 Super Duty Cars & Trucks
Fujitsu power supply shutdown goes to standby mode. no picture. If I turn it off for a while I get great picture and after a while it shuts down and goes into standby mode. Is this a power supply that is...
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in the P42HHA10 model. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A similar Service Bulletin is probably available to suit your model. A competent service technician should be able to implement the service bulletin.
Jun 02, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu Plasma Screen won't power up
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Toshiba Satellite A135-S2276 bios password resetting.
Toshiba will have it fixed free of charge:
Read this Toshiba bulletin:
your model is listed in the bulletin:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=1863789
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Fujitsu P50XHA10E no picture
See Fujitsu Service Bulletin on this problem. -see link below
Oct 24, 2008 | Fujitsu P50XHA10 50 in. Plasma Television
Turns off after awhile
Apr 12, 2008 | Fujitsu Plasmavision PDS-4214 42 in....
Fujitsu 42" Plasma Display shuts off after 20 minutes
Oct 21, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Mitsubishi WD-57731 57" Projection HDTV Logo
142 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
