Question about Brother SE-270D Computerized Sewing Machine
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
  • 460 Answers
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Posted on Apr 03, 2011
  • gulfstream10 Apr 03, 2011
    no, because i already tried that, and the needle cannot pick up the thread al it does is get caught and then I have to take the needle plate off and clean out the thread caught in there.
  • Irene Tulloch Apr 04, 2011
    Have you re-threaded the bobbin and made sure the thread goes under the tension spring there and that the bobbin turns clockwise when you pull on the tail of the thread?
    You may have threads stuck somewhere down there, I put the end of the hoover in the **** lint out or use a can of compressed air.
    Are you sewng a very fine fabric which pushes down through the needle plate hole?
    Have you re-threaded the top threads (with the presser foot up), they may be too tight.
I need help with a white sewing machine model 765 I can't get it to sew it doesn't pick up the bobbin thread
First thing to try is a brand new needle. A bent/damaged needle may not be able to pick up the bobbin thread.
Otherwise, it is possible it has a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to connect with the bobbin thread. Search the internet web sites and videos. There is a lot of information on how to fix sewing machine timing. Or take it for service.
Jul 11, 2016 | White Sewing Sewing Machines
My tension went out of sync now its not even picking the thread up
Try installing a brand new needle. Verify you are using the correct needle for your machine.
Remove the upper thread. Always raise the presser foot and rethread from the beginning. Make sure the threading path is correct.
Set the tension to the midway point between high & low numbers (this is usually the factory standard, although each machine may need a slight tweak and the type of fabric & thread may require a tension adjustment).
Check that the bobbin is inserted properly in the bobbin case and that the bobbin case is threaded correctly.
Retest your machine.
If it is still not picking up the bobbin thread, most likely there is a needle/hook timing issue. Take it for service.
May 15, 2016 | Janome Sewing Machines
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
The machine stopped sewing, the top thread doesn't pick up the bobbin thread, even when I just installed a new bobbin and try to just run the machine by hand to pick up the bobbin thread.
Have installed your bobbin right? By this, I mean drop the bobbin in but make sure that you pull the thread through the tension spring by putting your finger to hold the bobbin in place, then pull on the thread to get the tension. Let me know if this works.
Jul 24, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have a Janome MB4 and have had so many problems with the tension. I use the same top thread and the same bobbin thread. Every once in a while, it sews perfect. Other times I have so many loops on the top...
Hi!
I was having the same problem(s) and I loosened the tension on the bobbin case and switched to prewound paper bobbins and everything sews beautifully.
Hope that helps!
-Donna Jo
Apr 10, 2009 | Janome Sewing Machines
Singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
231 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
