MAYTAG BRAVO Quiet series 300 washer - top loading 2010 model. I had to pull the internal basket to remove coins that had slipped by and were banging around. Nasty noise but I successfully cured the problem. Recently we've been experiencing a very bad stagnant water odor coming from the machine. I pulled the basket again and saw very dirty water full of black gunk settled in pockets at the bottom right before the pump suction strainer cap was. Unsure why it is there but that is definitely where the smell is coming from. Otherwise, the machine works great. Please help.
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
SOURCE: Maytag Quiet Series 300 dishwasher,
Our control panel is fine. For now. (The machine is only 3 months old). This is our problem--and I haven't yet seen this complaint at all over the internt: The lower wash arm is getting stuck on the bottom rack and stopping immediately. This seems to be a design flaw. The bottom rack is just built too low. A service man was out once. He tightened the wash arm. Didn't work. The service department at the dealership is now ignoring our subsequent calls!! So I wonder if the "not cleaning" problem you have is because of this.
Posted on Apr 05, 2009
Healeyman
  • 1198 Answers
SOURCE: The suction and water flow is greatly reduced
It's possible to wear out the impeller. To remove the impeller: after removing the motor and impeller from the housing, you remove the cover from the electric end. Carefully find a flat on the shaft that usually fits an open end wrench close to where the shaft goes into the motor. Not on the end of the shaft where the spring thing is. Hold the shaft with a wrench while turning the impeller, don't let the wrench break anything. Double check the threads on the new impeller to see if they are left-handed. The impeller should unscrew in the direction of the motor's rotation.
Put in a new seal while you're there.
Posted on Apr 17, 2009
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
Maytag Bravo gas dryer gets too hot.
Most likely needs a new thermostat. Go online to find instructions on replacement. Make sure it is unplugged. I don't think it is too difficult to do yourself.
Sep 13, 2014 | Maytag Dryers
I'm moving and need to drain the washer. How do I
What is the model number of your unit?
Nov 03, 2012 | Washing Machines
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Ld error on Maytag Bravo. How to remove items stuck under tub?
if you can see the socks you may be able to remove by making a wire hook with an old coat hanger or something similar if you are able to undo the hose coming out of your bowl to the water pump you may be able to also fish out the coins if you are lucky but the best way is to dismantle bowl let me know how you went
Nov 07, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
