Question about Kenmore Washing Machines
I have a Kenmore 2800 series top loader which was delivered only about a week and a half ago. I was doing a load of laundry when it stopped working. The drum was filled with water but wouldn't drain. I cancelled the cycle, removed some clothes and put on the drain/spin cycle. Nothing happened. The washer won't sense anything... I hear a whirring noise as if the motor is trying to work, but nothing. I removed most of the water by hand (about 90%) and tried every to start just about every other type of cycle. Same whirring noise. I unplugged the entire washer and tried to restart; nothing. I've done about 15 loads so far, and this is my first problem.
  • 113 Answers
SOURCE: kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Posted on Dec 19, 2008
  • 47 Answers
SOURCE: I have a kenmore series 70 washer, top loading.
Chack the door swith. Use you finger or a pen to push the switch in asit would if the door (lid) were closed. If there is no switch to push in, it may be broken away but there might be enought left there to see/check and test if that is what needs to be replaced.
Posted on Nov 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Oct 01, 2010
  • 1937 Answers
SOURCE: I have a Kenmore 500
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The easiest thing to check (and likely the problem) is the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jan 10, 2011
Andriod Man
  • 271 Answers
SOURCE: KENMORE 90 SERIES TOP LOAD WASHER WONT SPIN LOUD
does it agitate???. if it does not then you need the motor coupling. you need to remove the cabinet, yes, I said the cabinet, remove the pump,motor and you got to the coupling. replace all part in kit. reassemble and test. go to the website of sears parts WITH THE COMPLETE MODEL. and get the part. model starts like 110.xxxxxxxxxxx
good luck to you.
Posted on Feb 07, 2011
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Laundry soap Residue
As a last resort add about 200grams of washing soda crystals to the drum before you start the wash.
Jun 24, 2009 | Kenmore 22422 Top Load Washer
I have a kenmore 80s series top loader washing machine. The water does not drain all the way on the spin cycle. I have to always run a second spin cycle
I know this sounds goofy but it sounds like the machine has been over loaded a few times and each time the machine is over loaded it makes the springs weaker. That makes it easier to overload with less laundry. Try to put less clothes in and see if that helps. Good luck.
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 70 Washer stopped working
I can't remember the wiring diagram for this model....but I would check the lid switch first. Lmk if that's it....otherwise you may have to dig in with a meter.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Top half of dual agitator stop working.
Most likely th agitatot dogs have worn out.. The part number is80040. They are located inside the agitator thy look like quotation marks. There is also a kit available which includes the dogs but more often it is just the dogs that are the problem. Good Luck.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite oasis (canyon capacity) top load washer
The button interface on the console has failed and will need replacing. Read owners manual for possible limited warranties on electronic components.
Jun 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
230 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
