Question about Pride Mobility Victory 3 Wheel Electric Scooter
I think I have a lemon Pride victory scooter.We have replaced the throttle pot,speed control, 2 new complete transaxles with brake and motor, and batteries and it still does not work properly. After about 20 minutes of running, suddenly the meter needle slowly goes into the red. These batteries just came off the charger and we have tried 2 sets.The motor 's tempture feels normal for the first 15 or 20 minutes but then it feels very,very hot. I believe the batterie are almost completely discharged at that point.My technician is at a loss as to where to go from here as he has done all of the above repairs. Pride is no help as they will only talk to technicians which he has done. Any Ideas anyone.
  • osaki2000 Apr 03, 2011
    How do u disconnect the charging circuit from the battery ?? Robert stearns
  • 635 Answers
Do you have any idea how hot the motors should run under normal conditions ?. The only way to confirm is to connect an Ampere meter in series to the motor while running. For which you will have to disconnect the positive wire ( RED ) going to the motor and connecting a 25 Amps Amp meter in series. Run the scooter after a full charge and monitor the reading, if after the mentioned 20 minutes the reading starts shooting up to more than double you are having insulation breakdown in the motor. It means replacement of the motor or rewinding.This insulation breakdown is what causes our house MCB's to trip when a faulty the washing machine runs for sometime.The enamel coating in the motors copper starts to short the windings on heating up thus increasing the current consumption. hats why the Amp meter in setries.
Second thing you can check is
After a full charge disconnect the charging circuit from the battery and then try driving and see how long it runs. The battery charging circuit has a rectifier which can go faulty and can short when hot.
Posted on Apr 03, 2011
  • 3,740 Answers
I think you have a termperature sensor related problem. Most every model of Pride Scooter has this statement in the troubleshooting procedures:
! Determine the temperature of the power chair at the time the problem occurred. The (add your model here) electrical system will protect itself from overheating when its internal temperature gets too high by reducing the amount of power sent to the motors. When this happens, the power chair will gradually slow to a stop. Allow the power chair to cool down and it will resume normal operation.
What if the range per charge of my (add your model here) diminishes over time?
! Determine if the batteries have ever been replaced. Batteries over a year old may be defective.
! Determine how frequently you charge the batteries in comparison to how often you use the power chair.
If you use your power chair on a daily basis, you should charge the batteries every day for 8-14 hours.
! Determine when the batteries were last charged. Even if the power chair has not been in use, the batteries should be charged once a week for 12-14 hours.
! Determine how long you let the batteries charge. It takes 8-14 hours to fully charge a depleted set of
batteries; continual undercharging reduces the overall life of the batteries.
! Observe the battery condition meter during battery charging to determine if the batteries are receiving a charge. If the battery condition meter does not go up when the battery charger is plugged into the charger power cord receptacle and an electrical outlet, the batteries are not getting charged. Check the charger fuse and ensure the electrical outlet is good.
! Determine if a wall switch controls the electrical outlet used for battery charging. If a wall switch does control the outlet and the switch is turned off inadvertently, the batteries will not fully charge.
! Is an extension cord being used to connect the battery charger to the electrical outlet? Pride prohibits the use of an extension cord when charging the batteries. The charger should be plugged directly into a properly wired standard electrical outlet as the length and condition of the extension cord can have an adverse affect on the battery charger.
! Determine how far you let the battery condition meter LEDs go down before charging the batteries. If
you continually allow the battery condition meter LEDs to fall into the red area, the overall life of the batteries will be reduced.
Ok enough with the copy and paste. I would also be looking at wiring harness plugs for any heat related signs on the plugs and connectors. A loose connection caused by heat / bad connections will turn the connection and the harness into a heating element. A complete harness inspection is necessary from the battery, relays, the joystick and the drive motors. Any sign of chaffing on the harnesses also. The wiring harness is a KNOWN problem with these scooters (at least by those of us that work on them) due to connector problems.
The only other thing I can think of is that maybe the drive motor and the brake are being actuated at the same time. (You would think due to design it would just lock up if this were the case.) However, If the drive voltage is higher than the brake voltage then it is possible to get slower than normal movement and rapid battery depletion.
I really believe you have a temperature related / normal operation problem. The soultion is going to be find out why there is such a rapid heat build-up that causes the scooter to slow down and stop as it gets hot. (^-
Kelly
Posted on Apr 04, 2011
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
I need to know how to replace the power pot on a pride victory 3 wheel electric scooter
hi, do you mean the throttle pot or the speed pot ? located on the tiller panel ..
Regards
Rob
www.gewizrepairs.co.uk
May 02, 2014 | Pride Health & Beauty
Pride hurricane, pre 2004, when throttle is released at any speed, the mag brake activates immediately instead of allowing the scooter to slow naturally, then applying the brake. all appears to be ok, is...
Things to check : Condition of the brake actuator and the condition of the brake shoes. If there are no flashing lights indicating a problem with the controller, then I would think it's all mechanical.
Sep 12, 2013 | Pride New Mobility Victory XL 4 Wheel...
Hi: When I take my thumb off the throttle my brakes do not work as fast as they use to, it take awhile for them to engage. Is there something I can do to fix my Pride Rally 3 wheeled scooter. I think I got...
A 13 year old working brake on a scooter is remarkable. This brake part is available and can be purchased for between $60 and $260 retail depending on model and SN. Labor is under 1 hour. You can do it yourself, installing it on the end of the motor.
If you want to clean out the dust of the disc brake you can try a strong spray of air. The dust could cause slippage if the brake were a year or two old.
After 13 years you are ready for a new brake and a new scooter so I am not sure you want to put a lot a money into repairs.
The throttle potentiometer also controls the brake engagement when you release it. You may want to invest in a new throttle pot as well ($80). This item wears out regularly. Hope this helps.
Dec 02, 2010 | Pride Mobility Products Pride Mobility...
Could you please tell me where i will get forward& reverse throttle for pride victory
Throttle potentiometers are a frequent part that is replaced on scooters due to wear. This part is available from the manufacturer Pride or from a company called Monsterscooterparts.com.
At the Monsterscooterparts home page click on mobility scooter parts, pride scooters, pride parts click on Pride Victory XL SC270 , select throttle pot assembly. Verify SN and compatibility remarks. They have an 800 phone number for questions and they ship worldwide. The Pride part number is ELEASMB 1511 for Victory XL 4 wheel scooters after the year 2000. Looks like the price is about $80. Labor is about 1/2 hour and can be done by an experienced mechanic or do-it-yourself. The part is available from the manufacturer if you are a dealer or have an account.
First remove the throttle lever by loosening the allen set screws. Separate the front console covers by removing 8 or more screws holding it together. Locate the throttle pot, unplug it and install a new one. Be careful not to over-tighten or strip the screws holding the potentiometer housing tabs to the plastic. Check the alignment visually before reassembling it. Don't pinch any wiring when you put the console back together. When you reinstall the throttle lever make sure it is even left to right and does not bind on the plastic console housing. Tighten the lever set screws firmly but do not strip them, this repair will need to be done again and you want to be able to remove these set screws. Hope this helps.
Nov 07, 2010 | Pride New Mobility Victory XL 4 Wheel...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I have a pride scooter that will not run at top speed. When speed control is turned to fastest setting, the scooter goes dead.
hi, first check the speed throttle by moving it in the upwards direction while the speed control is turned fully on, if there is a response to moving the speed pot in up and down direction , you founf the fault, otherwise the speed control is at fault, if thats proves to be okay then its the controller breaking down , check the brushes on the motor.
regards
GeWiz
Oct 30, 2009 | Pride Mobility Victory 3 Wheel Electric...
I have a pride victory scooter and at low speeds it shutters and gets worse when it gets hot and worse in reverse..
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Oct 04, 2009 | Pride Mobility Victory 3 Wheel Electric...
I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Jun 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Mobility Victory 3 Wheel Electric Scooter Logo
240 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
