Question about GE EasyCam Pro Webcam
Instlled webcam, but can't get microphone to work
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
Have web cam problems.. can't on web cam
try to reinstall the webcam drivers if shows any error then un instll the webcam driver and reinstall the driver once again.even though the webcam is not working then it is the problem with the cable or camera so you have to consult hardware technition
Feb 16, 2011 | Acer Aspire 4315 Notebook
My webcam does not work even if it is instlled and my computer does not any icon instead for webcam
Hi.
Based on the information you have provided, it seems that the issue might be due to the Webcam Driver.
Hence, it would be better to re-install the Webcam Driver.
You may download and install the Webcam Driver from the manufacturer's website.
Once you have installed the Webcam Driver, please restart the Computer.
It is required to restart the Computer for the settings to be enabled.
Please try re-installing the Webcam Driver.
Re-installing the Webcam Driver should resolve the issue.
Hope this helps.
Please feel free to contact for further information and assistance.
Dec 19, 2010 | Compaq Presario M2000 Notebook
Microphone not working
How to get your webcam microphone to work: Click on Control Panel, Hardwre and Sound, Sound, Recording. You should see your microphone icon with a Green check mark on it. If there is no Green check mark, it means it is disabled. If there is No green mark on Microphone it never works. To enable the Microphone Right click on Microphone and click on Enable. If you do not see the Microphone in the list, Right click on the White space and select Show disabled devices. Then you would see the Microphone. However, if you do not see the green check mark on it, Right click on it and click on Enable. And also Select Microphone and click on Set Default (If Set as default button is active).
If you see the Green check mark on Microphone the Microphone definitely works.
Step 3: Increasing Microphone Sensitivity and Un-muting the Microphone.
1. Select Microphone and click on Properties button.
2. Adjust the slider until to 100 % of its range.
3. If Mute is on, click the mute button to un-mute the device.
4. If Microphone Boost is available, boost the volume.
5. Click OK to make the changes.
Now the Microphone should work. To verify you can test it on the free webcam test tool site.
Jul 01, 2010 | Logitech Webcam
I have genius sub web cam but not cd how could i downlod drivers
plz go on compny site and download the driver and simply instll the cam drive than ur cam is working properly
Jun 03, 2009 | Veo Connect Webcam
I got the program just cant get into it
i have lost my web cam driver cd so please give me soution how to install it model numer pd1001 series number n10225
Apr 10, 2009 | Creative Labs Creative Webcam
Icannot get webcam microphone to work.how do i hook up microphone
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Mar 14, 2009 | Logitech Quickcam Chat Webcam
GE Perfect Image Webcam 1.3 megapixels, installed software, microphone won't work, camera is fine
Nov 03, 2008 | GE MiniCam Pro HO98656 Webcam
Microphone on my webcam
Aug 27, 2008 | Computers & Internet
Microphone will not work
problem solved thanks had to book into a stress clinic but still I have a microphone thanks for the message
Feb 15, 2008 | Microsoft LifeCam NX-6000 Webcam
Open Questions:
http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip http://67.19.107.18/mirror0/getfile.php/GE_Easy_Cam_HO98063.zip?hash=39d52de536231ab9339477c999c2e1d3&did=164366&source_url=&lfile=GE_Easy_Cam_HO98063.zip&time=1217515688&auth=e42cf1d9bdfbd52df658599d0433bc94&file=GE_Easy_Cam_HO98063.zip
Feb 27, 2017 | GE EasyCam Pro Webcam
See all GE EasyCam Pro Webcam Questions
GE EasyCam Pro Webcam Logo
15 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
