Question about Generation GM7807 Corded Phone
HOW TO SET UP A GENERATION GM7807 WITH THE DATE
WHAT IS RELEASE DATE FOR ECHO DOT 3RD GENERATION
Call Echo company to give you the release date.
-For most people is not important. We care only how long it will last, and how easy to use.
Good luck
Mai
Jan 24, 2018 | Echo Computers & Internet
How can I tell how old my iPad is?
5 February 2013
iPad (4th generation) - Wikipedia
https://en.wikipedia.org/wiki/IPad_(4th_generation)On January 29, 2013, Apple announced and scheduled the launch of the 128 GB variant of 4th generation iPad. It was released on February 5, 2013. Following the announcement of the iPad Air on October 22, 2013, sales of the fourth-generation iPad were discontinued.‎History · ‎Features · ‎Hardware · ‎Reception
A1459 - Lookup Mac Specs By Serial Number, Order, Model & EMC ...
https://everymac.com/ultimate-mac-lookup/?search_keywords=A1459
Intro. October 23, 2012*, Disc. October 16, 2014**. Order, MD516LL/A*, Model, A1459 (EMC 2605*). Family, iPad 4th Gen (Wi-Fi + Cellular), ID, iPad3,5.
iPad (4th generation) - Technical Specifications - Apple Support
https://support.apple.com/kb/SP662?viewlocale=en_US Oct 14, 2016 - Model A1459*. GSM/EDGE (850, 900, 1800, 1900 MHz); UMTS/HSPA+/DC-HSDPA (850, 900, 1900, 2100 MHz); LTE (Bands 4 and 17).
Identify your iPad model - Apple Support
https://support.apple.com/en-us/HT201471 Sep 21, 2017 - A1459 on the iPad (4th generation) Wi-Fi + Cellular A1460 on the iPad (4th generation) Wi-Fi + Cellular (MM); White or black front bezel ...
Launch Date here
ipad a1459 launch date Google Search
Oct 04, 2017 | Miscellaneous
How do i change the date on my kindle fire 5th generation
Your instruction manual is here. Settings are on page 117, but there is nothing on changing the date. It does mention that books are dated, and I wonder if that is what you are seeing.
http://kindle.s3.amazonaws.com/Kindle%20User%27s%20Guide%2C%205th%20Edition_English.pdf
Nov 22, 2015 | Tablets & eReaders
How can I up date my IPad?
Depends, When you have an iPad first generation, you can't update to iOS 6. All other iPads can upgrade to iOS 8.0.
In the few years your iPad is around, the processors are much faster. There is more internal memory and so on. Please to avoid you can't upgrade your next iPad, don't buy a second or third generation.
If you have a newer iPad than the first generation, just goto settings, general, an then the second line from the top says software update. Press that one. Your iPad will look if any update is available, and suggest to download and install it.
But the best way to upgrade, is connecting the iPad to iTunes and click on the name of the iPad on the left side in the menu, then click on upgrade.
Sep 27, 2014 | Apple iPad Tablets & eReaders
4.2.1 to 5.0.1
ipod 1rst and 2cnd and some 3rd generation won't update further than 4.2.1 ios. only 4 and 5 generation will be able to update 5.X.X or more. sorry for bad news =/
Apr 18, 2014 | Computers & Internet
I want to know which generation is the Ipod 30G model A1136, thanks
There are two 5th gen iPods, A1136 model is the older 2005 model, not the later 2006 model.
Here is Apples link: http://support.apple.com/kb/HT1353#ipodfifth2 which will show the differences, but not by model number. The reason I know this model number is the first 5th gen 2005 is because I have one. Also older 2005 should have '2005' engraved on rear.
May 29, 2009 | Apple iPod classic 5th Generation
Ipod touch problem
keep up to date on all software/ security updates from apple.com , you can download the newest and safest software there, you can always turn off your WiFi when you aren't using your touch to avoid excessive time online . hope this helps :)
Nov 16, 2008 | Apple iPod touch
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Generation GM7807 Corded Phone Logo
71 people viewed this question
Top Generation Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Generation Lands Phone Expert? Answer questions, earn points and help others
