Question about Brother Sewing Machines
While sewing, I am getting skip stiches from the top and lot of thread is accumulating at the bottom, as a result it's getting stuck. Please advice. Thanks
  • 458 Answers
I suspect the thread has not passed through the tension discs correctly. Try re-threading and remember to raise the pressure foot when you thread. Or try cleaning the tension discs as there may be stray bits of thread stuck there.
Posted on Apr 03, 2011
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Why is the bobbin thread being cut on bobbin after a few stiches? machine will sew a few stiches and this happens.
your bobbin is place in the wrong position and you need to tighten the stitch....adjust it a bit.....play with it till you get the desire result
Sep 11, 2014 | Singer Sewing Machines
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
Breaking uper thread & skipping stiches
Your problem may be the quality of thread or the type needle you are using ...
Jun 30, 2012 | Sewing Machines
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on www.sewing.about.com or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
Tread breakage snd stich skipping
(A)Put in a new needle and rethread from the beginning. Make sure the take-up hook is threaded. Also, (B) clean lint out - sewing machines have very small margin for error when lint pushes everything out of alignment. Mostly, it sounds like your thread is stuck somewhere, which can even be at the spool, so (A).
Apr 06, 2010 | Juki DDL-8700
Thread loops
Proper set of bobbins and tension set up vs. fabrics will sew you satified.Also incude regular maintenance cleaning of the feeds dogs with a brus,also the shuttle assembly need sometime to clean.Some threads and fabrics chips accumulates in the feed dogs and shuttles assembly.In setting up thread bobbins the thread should be clockwise direction as you pull out on slot coming out to the bobbins (as you shown in my inserted image manual).The loop thread should be propely in the sequence position same like in the image refer to it.If you use cotton/ polyester fabric in the begining of trial set tension dial to No.3 and stich to No. 8 to 12 any convenient to you Use needle No. 14 .Posible make a record if you are sewing different types of fabric mostly silk fabric is hard to sew adjusting to lower stich can posible sew satisfactory.
Mar 10, 2009 | Consew 206RB
Tension problems (?)
Well, I could have written this. I bought a used model from a repairman about a year ago. I have a Model 537FA and I'm going to throw it out in the rain leftover from TS Fay if I don't find some kind of help. :) I'm thinking it's a tension issue, but I can't seem to find a fix.
Does your tension on your top thread sometimes tighten to impossible to move in the middle of sewing. I know that mine does this and it causes the top thread to break. I don't know what's causing the bobbin mess.
Maybe someone will help us? Please!
Aug 23, 2008 | Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
