Question about Eiki EIP-2500 Multimedia Projector
Is it possible to connect a projector and a flat-screen tv and control both with a laptop computer? (the flat screen would be used instead of a projection screen)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
When connected at the same time, you need an active signal splitter, or
connect the flat screen to the monitor out terminal of the EIP-2500.
Posted on Apr 17, 2014
5 Suggested Answers
  • 110 Answers
SOURCE: will this projector work for HD TV?
While the projector may attempt to display the HD TV, it will be poor quality if a image is displayed at all.
The native resolution is to low as per the specifications. The resolution needs to be at at leat 480P to be compatble with HD TV.
Posted on Aug 22, 2008
  • 489 Answers
SOURCE: Can't project video from laptop connected to NEC NP100
you can plug in to a laptop if the laptop has vga out. affter plug play the film or something and give the view to projector. need to pushing special button on keyboard. which is with FN
Posted on May 30, 2009
SOURCE: projector can't connect to laptop
We just solved a similar issue. Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
For the PICO in particular, it looks like those are in general for small mobile devices (320 x 240 or less displays), and the PK102 model has native VGA (640 x 480) support with extended support for 800 x 600. You will not be able to use this on most modern computers except at the lowest resolution setting for the PC.
Posted on Oct 16, 2009
Salim Baig
  • 283 Answers
SOURCE: I have a DELL XPS
Hi
Sure can be fixed.
1st of all you need to connect the projector with your laptop turned off. One the laptop has finished booting and loading windows. Hit the Fn+f4 or f7 key to switch between the displays then you will get the display.
But if this also does not give display then you can check with the projector with Video INPUTS (Eg. Input 1 / Input 2 etc.,)
Posted on Jul 21, 2011
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
When using the computer with my projector my computer goes blank because i am not actively using it just having students view the screen what can i do
"test test" offers a good answer but misses out the possibility that your laptop "Power Settings" might be turning off your screen display. So if the problem persists after going through all the things already suggested you could go to your laptop's control panel to the Power Options and click on "Change when to turn off the display". Good luck.
Sep 08, 2012 | NEC VT676 Multimedia Projector
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
Laptop connected to projector get initial message "no signal" then projector continually searches through video, computer 1 and computer 2 - what do I do?
Make sure that you have enabled the 2nd screen output from the laptop. It sounds like there is no signal at the input of the projector. You can check this by connecting a monitor to the 2nd output of the laptop. Often you have to press one of the function keys (F5 possibly) to enable the 2nd screen from a laptop.
Feb 01, 2011 | Hitachi Performa CP-RS55 Multimedia...
How do you hook up cable tv to my epson powerlite 830p lcd video projector
To hook up cable tv, you will need to have the cable running into a vcr 1st, then run either your s-video cable or audio video cables into the projector. Press the Source Search button on the remote control or the projector repeatedly until you see the image you want to project on the screen. The projector has two Source buttons.
Use the Computer/Component button to switch between equipment
connected to the Computer/Component ports.
Use the Video/S-Video button to switch between equipment
connected to the Video and S-Video ports.
? The remote control has four Source buttons. Use them to switch
between devices connected to the ports identified on each button.
(The PowerLite 830p does not support EasyMP.TM)
You can preview all sources on one screen to help you select the
desired source. (Allow a few seconds for the projector to sync up
after pressing the button.)
Feb 01, 2011 | Epson PowerLite 830p Multimedia Projector
I have an Element 32" flat screen tv model # ELCHW321 that i am trying to use as a computer monitor via vga to vga connection and am not having any luck. The tv says no signal. I have tried a newer laptop...
When you are using a laptop you have to press and hold down the function key and hold down the dual monitor key (either F5 of F8) for about 15 full seconds. The screen of your laptop should darken and the image should come up on the tv screen.
May 06, 2010 | Element Electronics FLX3210 32 in. LCD TV
Connect laptop(with HDMI output) to TV( with s-video input)? Hi I have a laptop in which there is port for HDMI output and TV with S-Video input. I bought a cable (HDMI HDTV to VGA HD15 Y/Pb/Pr 3 RCA...
Here how you can connect a computer running windows vista to projector or other external display.
  1. Open Personalization window by right clicking on empty desktop and choose "Personalize",
  2. In the Tasks list click on "Connect to a projector or other external display" link,
  3. The Windows Mobility Center appears, in the presentation settings box click the turn on button to turn on projector,
  4. Now your screen will show up on projector screen around large display as well as your own computer screen,
  5. If you want to change the presentation options click the Projector icon inside presentation setting box,
  6. The Presentation Settings Windows appears, if you turned on the projector the "I am currently giving a presentation" checkbox is selected,
  7. When you are giving a presentation your computer stays awake, system notification are turned off and by default the screensaver is turned off,
  8. You can also set the system volume to show different windows wallpaper in the one you usually use, when the presentation ends and you turn off the projector your regular desktop wallpapers returns,
  9. If you are not sure what displays are connected click "Connected displays..." button on bottom of existing window.
Jan 10, 2010 | Office Equipment & Supplies
Can not figure out how to use projector with laptop.
maybe you need make a configuration in settings f2 or f12 to avaliable the vga port out
Sep 16, 2009 | Toshiba Satellite 1405-S151 Notebook
I just purchased an Acer X1160 Projector and obviously am not savvy enough to understand what to do to make it work. When connected to my HP Laptop I get the image of my screen saver, but cannot get...
Your computer is probably using the projector as a second screen instead of displaying a copy of the laptop screen.
The quickest way to confirm is to try moving your cursor (mouse) off the right-hand side of the screen. Does it then show up on the projector? If so, then you can grab and move windows back and forth between the two screens.
If that solves it for you, please be sure to click the thumbs-up.
If not, add a comment and I'll try to explain
Sep 02, 2009 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Infocus projector 4805 connected to Toshiba laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
2.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems.
Jan 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Eiki EIP-2500 Multimedia Projector Logo
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
color wheel light...
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
