Question about Acer Aspire 5100 3010 Notebook
My cd drive doesnt work, and it doesnt show when i open my computer. i have tried to run recovery and delete upper filters in registry entrys and it still doesnt work. is there any hope?
    Guru:
  • 382 Answers
After you have deleted the Upper/Lower filters, did you restart the computer? Since you made changes on the registry you need to restart the computer in order for it to take effect. This applies to any changes you made in the registry.
Thank you for choosing FixYa!
Posted on Apr 03, 2011
Dvd room does not work. Can not read CD, DVD or burn to CDs or DVDs. I have a Acer Aspire 5738ZG.
Hi Welcome to FixYa!
Is this happening on all CDs or DVDs? if it is, the issue that you are encountering could be a software or Hardware issue. Follow the steps below to find out.
1)If its a sofware issue, it could be with the Upper or Lower filters settings for the cd/dvd rom on the registry that is causing you the problem. You could check it by opening Registry Editor. (click on start>type "regedit" on the searchbox and open it. You should be seeing something like the picture below : mondimondz_2.jpg
2)go to this entry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} That is the key entry for your CD/DVD rom.. Once you are on that key, look at the right panel, and search for Upper Filters or Lower Filters. If you see those entries, delete them. Be careful not to delete some entries on the registry aside from those two.
3)after deleting them, restart the computer.
4)Once you get back into Windows, try to load any cd or dvd and check if it will now be able to read them.
5)if it still does not work, try to go to your computer manufacturer's website and download the latest firmware for your CD/DVD drive.
6)If all else fails, try replacing the CD/DVD drive on your computer.
Hope this could be helpful!
Have a great day!
Jun 22, 2011 | Acer Aspire 5610-4648 Notebook
I am using windows 7 my dvd rom dose not read cds but is listed in my computer
Is this happening on all CDs or DVDs? if it is, the issue that you are encountering could be a Software or Hardware issue. Follow the steps below to find out.
1)If its a sofware issue, it could be with the Upper or Lower filters settings for the cd/dvd rom on the registry that is causing you the problem. You could check it by opening Registry Editor. (Click on start>type "regedit" on the searchbox and open it. You should be seeing something like the picture below: mondimondz_2.jpg
Have a great day!
Jun 20, 2011 | Sony Computers & Internet
When i put a cd in my cd/dvd rom it wont play dvd movies nor cd's, it wont show the dvd movie in windows media player nor itunes nor quickplay. the rom says dvd rw-r and those are the dvds i play and...
Try to run the following hyperlink
Hyperlink to microsoft automatic assistance
Hyperlink to Cd drive autofix
If it doesnt work then try following steps:
  1. loadTOCNode(2, 'resolution'); Click Start, and then click Run. (in case of windows 7 click start, look for search program and files , type in there regedit and hit ok, jump to step 3)
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:
  1. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click
    UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters. (dont panic if you dont see lower filter)
    On the
    Edit menu, click Delete. (or simply right click and select delete)
  5. When you are prompted to confirm the deletion, click Yes.
  6. Exit Registry Editor.
  7. Restart the computer
Apr 20, 2011 | HP DVD DRIVE DVD Drive
Inspiron 1100 wont recognize dvd/cdrw cd burner drive
    On the
Feb 22, 2011 | Hitachi Dell INSPIRON 1100 5100 5150...
My Pc is unable to read any cd . there is no cd rom drive icon on my computer.
Please just follow the below steps and fix your problem.
1. Click Start, then Run, then enter REGEDIT to open the Registry Editor
2. Navigate to the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class entry
3. Under the Class entry, double click on {4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right-hand pane, click ONCE to select the Upper Filters entry
5. Make sure the Upper Filters entry is highlighted, press Delete, then Yes.
6. In the right-hand pane, click ONCE to select the Lower Filters entry
7. Make sure the Lower Filters entry is highlighted, press Delete, then Yes.
8. Close the Registry Editor by clicking File, Exit
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 05, 2010 | Dell OptiPlex GX260 PC Desktop
Cant install ND 6650A code 39
The issue is with the registry of the Computer. Please follow the steps to resolve the issue. Please back up the registry before performing the steps.
  • Please press "Windows+R" key to open the Run command, type regedit and then click OK.
  • Please click on File-->Export and then enter the name and select the location to backup the registry.
  • In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE-->SYSTEM--->CurrentControlSet-->Control-->Class-->{4D36E965-E325-11CE-BFC1-08002BE10318}
  • In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry.
  • On the Edit menu, click Delete and select Yes to confirm.
  • In the right pane, click LowerFilters, on the Edit menu, click Delete and select Yes.
Note If you do not see the LowerFilters registry entry, exit the Registry.
  • Exit Registry Editor and restart the Computer.
This should resolve the issue.
Good Luck!
Thank you for contacting.
Jun 29, 2010 | Dell DVD-rom DVD Drive
My Hp pavilion 533w Desktop's dvd drive wont open or blink(light)
Try the brute force method: stop the pc, open its case, disconnect the data cable from the dvd, close the case and reboot, run a registry cleaner,stop the pc, make sure the hard disk is set as master and the dvd set as slave and reconnect the dvd, start the pc.
May 05, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Hp dv6917cl computer does not show cd rom on screen unable to boot from cd drive or use cd drive at all. tried switching drive out still same problem light comes on during start up on the drive door but...
► check for the registry entry h_key local machine -> control -> current control set -> class and check for the registry entry 4D36E965 and under this entry you would find the upper filters and the lower filters and delete the entries restart the computer if this does not work ► check in the device manager for the cd / dvd drive if the driver has a yellow exclamation mark put a right click and uninstall the driver restart the computer ► if this does not work reseat the optical drive ► if this does not work then needs to perform a recovery if it does not work after the recovery then it is a h/w issue and needs to replace the optical drive
Feb 19, 2010 | HP Computers & Internet
DELL Inspiron 6400. CD/DVD ROM cant read any cd/dvd used to work before but not working anymore. updated the firmware from Dell website, done the upgrades etc.. still doesnt work? help please.
If the drive still spins up when you insert a disk it sounds like the lasers have picked up dirt/dust or have burnt out. Try opening the drive door and blowing hard into the aperture (without spitting). If that doesn't help then I would suggest replacing the drive. I assume that you have tried the disks in another machine and that they run fine.
Jun 07, 2009 | Dell Inspiron 6400 Notebook
Acer Aspire 5100 3010 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
