Question about Whirlpool Dryers
Modle # wed6400sw power comes on but it will not start. The switch on the door is working
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 03, 2011
How do I replace the door strike on cabrio dryer 5600
Door strike or catch the strike is on the front panel which means removal of front panel
Sep 04, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
My starter botton won't work on my cabrio dryer
u need to ometer test the push start button , the thermo fuses and thermostats, of course u have already checked the electrical plug for power? test also to see if it is getting 220 at the cuicut and back of applaince
Apr 27, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Intiorlight and door light comes on by itself after door is locked
You have a defective door jam switch. It is a common issue with Ford products. The switch is actually in the door for this year modle.
Mar 02, 2011 | 2002 Mercury Sable
4wd does not work iv changed the 4wd switch but still does work and on the 4wd switch none of the lights come on to tell you if you are in 2wd or 4wd hi or low
the switch is probably from a newer modle truck, although they work the indicator lights don't always work, and check the 4x4 fuse in the fuse panel on the left side of the dash by the drivers door
Nov 07, 2010 | 1999 GMC Sierra
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kia sportage modle 2004 wroof light direct on
make sure the switch is sey correctly,it can be set to off or on all the time or set to turn on with open door, so check the switch position first. next thing to check is for a door not closed good then for a bad door switch.
Mar 10, 2010 | 2005 Kia Sportage
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
Dryer is getting Power but not coming on.
Check the following---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 01, 2009 | Roper RES7646KQ Electric Dryer
Dryers Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
