Question about Sony VAIO RB30C (VGCRB30) PC Desktop
When I turn off the cpu with the windows shut down or sleep or power button it will only return when you toggle the power to the psu on and off, When you push the power button to restart or start up the green light on the psu goes off and you can only start it b y cutting power to the psu then restoring it (see video http://www.youtube.com/watch?v=0LmltrJacP8) the original psu was replaced with a bestac equivalent. I a have tried removing the power button and bridging the pins but I got the same results
  • 124 Answers
Very similar problem
1. Is there a GREEN blinking light on the motherboard?
2. Check you BIOS setting. These motherboards have software installed to check voltage readings to and from the motherboard.
Posted on Apr 03, 2011
I have a Gigabyte EX38 DS4 motherboard. A few months ago the power light light would blink after I shut windows down and it wouldn't turn on again. If I unplugged the computer for a while it would stop...
As you may already know, your computer will shut down after power on if if the power supply does not receive a power good signal from the motherboard. Since you already tested the PSU in another computer, and you know the PSU is good, either you have a bad mobo or some device connected to the power supply is draining excessive power from the PSU and causing it to shut down.
Try removing the 4 pin pin power plugs from ALL devices, such as the floppy drive, CD drives etc.
If the system stays on when you power up, then you can isolate the faulty device by re-connecting them one-by-one. If the system still shuts down your Mobo or CPU is bad and you might want to take it to a PC technician to determine if it's worth fixing.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 18, 2011 | Intel Motherboard
My pc starts normally, but after an hour or two when i click windows shut down windows closes, and no signal message is shown on monitor.But the CPU Fan, GPU Fan & Cabinet Fan running normally,they...
There are two harware you should check,
First the memory, it might be malfunctioning, if you have an extra memry card, try to swap it just to test the syatem.
Second will be the power supply unit or PSU, that is already overheating and shutting itself down, thus its not powering the your hard disk. try to replace it if you have an extra PSU.
Those are the most probable problem you have, PSU is the main problem in any desktop that was always been overlooked!
Hope that helps you out!
Thanks for using Fixya!
Dec 16, 2010 | Intel DH55TC Motherboard
When i shut down my pc it shuts down, but the psu stays on, i can turn it off by the button but not by the desktop, any ideas???
Hi, "Sleep" mode or "standby" mode allows your computer to go on standby or sleep until you "wake" it up again. This is a power saving feature which is usually used for a few hours. You can change it to completely shut down everything (including power supply) in power supply options in your control panel. Check out your help section for sleep or standby options. Hank
Aug 27, 2010 | Dell Dimension E520 PC Desktop
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
Sleep mode wakes up on it's own
turning off all the power saving items does not help this- it just ensures that it doesn't automatically power down your hard drive or shut off power to your monitor automatically when you aren't using it.
May I suggest Hibernation Mode as an alternative? this mode saves everything you are doing to disc and shuts your computer down completely. when you turn it back on, it will restore what you were last doing onto the screen, so you can pick up where you left off.
you can find more information on this and sleep mode from here: http://windowshelp.microsoft.com/Windows/en-US/Help/335c6a5d-0304-4af1-b135-6bf6c124dc111033.mspx#EZAAC
Cheers,
-Demolitio
Aug 03, 2009 | Microsoft Windows Vista Home Premium with...
Emachine t5026 not power on. replaced psu.
I would test the memory. Also I think some computers will shut down if the fan on top of the CPU quits working. Or maybe one of the other fans or the Hard Drive quit and is drawing too much juice causing the PSU to shut down. It sounds like something may be grounding.
Jan 02, 2009 | E-Machines T2642 PC Desktop
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
My tv urgent
Hi - first check that all the fans are rotating - the set will shut down if they are not.
***** WARNING potentially FATAL voltages (up to 400V DC) exist on the PSU boards - if you don't know exactly what you are doing don't ! *******
Unfortunatly the fault could be on a) PSU b) CPU board, as this monitors the PSU voltages and will shut down the set if the measured voltages are wrong c) plasma drive circuits - if these are drawing excessive current, or someother fault exists the fault feedback signal to the CPU board will activate and the set will again shut off.
Check the PSU voltages, the standby power must be OK otherwise the set wouldn't work at all !. The +5V switches on first followed by the +70V and +170V (about 1-2 secs delay.)
If the 70 and 170 dont come up try removing (with the power DISCONNECTED) the two large double row connectors on the PSU board near the 70/170 V test points - these supply the plasma drive circuits - the set will still switch off as there is a fault feedback line from the drivers, but it should stay on long enough to check the voltages.
Feb 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
65 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
