Question about Cell Phones
My phone is always on it's base until I lift it to use it. Since a few days ago, when I pick it up, press "talk", I see the message "no link to base. Move closer to base." Why is that happening?
Maybe the battery isn't holding charge. One of my home handsets can only be off the base for 30 minutes before it totally dies. I've heard that staying on the charger too long kills the battery.
Posted on Apr 03, 2011
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Want to know what flashing "ST" means in the answering machine counter
You will need to setup your answering menu date/time on the LED message indicator. Repeatedly depress ans. menu until it says to adjust the day, date, time of day in order to match your LCD settings.
May 08, 2009 | Lands Phones
Hearing a "music" when a call is made
I think I know this one, so please rate this a FixYa!
Do not pick up the handset. Press PROG press each line button TWICE. Press the Down arrow on the NAVIGATOR button. It will play ring tones in choices 21-30. Press ENTER to save.
You have to do that for each line you want to ring differently.
Carl
Mar 20, 2009 | Panasonic KX-T7630 Corded Phone
Thomson GE DECT 6.0 28213 Cordless Telephone
I finally find a way to stop this problem from occuring : never leave your phone on the charger with the battery isnt empty !
I know this sucks because what best place to put your phone at night than its base. But try it and it will work (unless your battery is already damaged). In the morning when i go to work, I charge it for 8 hours, then when I come back, I take it off the charge until next morning.
I used to put it on the charge for all night and all day until I read an interesintg post :
http://en.allexperts.com/q/Telephony-Clecs-Long-2450/Cordless-phone-interference.htm
Since I have been doing this, I didnt get any more problems with my phone.
May 28, 2008 | Thomson GE-28115FE1 Cordless Phone
Audio Feedthrough
wow, no one has posted a response for this poor sap. I don't know what to do, but someone should at least post some insight!
Personally, I think it may be a power issue, as possibly the current going to the phone is not stable, so it is interfering with the machine's abilities to listen for someone else picking up on the other end.
Nov 25, 2007 | AT&T 1855 Phone
Phone not working
You may need to re-register the phones. Below is a link to the owners manual in case you don't have one. Good luck. http://157.254.235.130/public/IB27996DOME0.pdf
Jun 13, 2007 | GE 27996 Twin Cordless Phone
Message Light flashing continously
Resetting the New Message LED
If the LED remains on after you’ve retrieved your messages, you may need to reset
the indicators. With the phone is in standby mode, press and hold find handset on
the base until the paging sound stops (about 5 seconds).
Dec 12, 2006 | Uniden TRU8865-2 Expandable System...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
