The motor is not spinning - Washing Machines
  • 668 Answers
If the washer will agitate but not spin I'd suggest you to replace the lid switch. Then you need to check the coupler is working properly or not. In order to provide you proper steps to access the coupler and lid switch. Please resubmit the question with some more details.
Hope this helps.
Shane
Posted on Apr 03, 2011
  • tammywarn683 Apr 27, 2011
    how do i check the lid switch?
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jan 06, 2015 | Maytag Washing Machines
Washer won't agitate or spin
Oct 12, 2014 | Whirlpool Washing Machines
My maytag bravos will not spin
Oct 10, 2014 | Maytag Washing Machines
Water loads up but does not wash nor spin but does drain
Motor Control Board he motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 09, 2014 | Maytag Neptune Washing Machines
Machine not spinning
Dec 26, 2013 | Asko Washing Machines
Motor will not spin. The battery indicates 24 volts and i wired the battery directly to the motor. Should this make it spin or can I be sure the motor is bad? I just want a fail safe way to know it is...
if your batteries are outputting 24 volts or more the motor should spin when connected directly to the battery, if the battery is putting out 23.9 volts the motor will not spin
Oct 01, 2012 | Electric Razor Pocket Rocket Ride-on...
Will not spin hear it spinning but tub does not spin
If you are hearing the motor spin but the tub doesn't, then the motor coupling is bad. The coupling goes between the motor and transmission and enables the transmission to spin or agitate. You're going to have to open up the machine so you can access the motor. Then you will have to disconnect the motor and you will see the coupling.
Feb 22, 2011 | Maytag PAV2300 Top Load Washer
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
The motor will not spin..... can i have a diagram of a motor of ultimate care ii washing machine
The typical problems with "the motor will not spin" is a:
1. Lid-switch (very frequent): Will not drain, incomplete cycling, switch ultimately passes power to motor.
2. Belt or coupling (very frequent) - Belt moves when motor spins
3. Timer/control board (rare)
4. Tranmission (rare)
5. Motor (somewhat rare)
How do you know the actual motor is not spinning? Do you mean, the tub not spinning? Do you have a noise as if the motor is spinning?
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
