Question about Karcher K3.68MR Electric Pressure Washer
My karcher 3.68 leaks water internally and won't spray
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: My Karcher 550M is leaking a lot of water at the handle of the spray gun
use teflon tape
Posted on Jul 23, 2015
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
Water blaster compressor still firing steadily even when in 'idle
No, there's no adjustment. And it wouldn't help if there was! The symptom you describe is very common, and it indicates that there's a leak somewhere. Unfortunately, there are several places where a leak can occur - it may be external (sooner or later you will see water coming out of the casing) or internal (water is leaking from the high pressure side of the pump back to the low pressure side, so you'll never see it). Unless you are a keen engineer, you're best advised to get this repaired professionally. However, get a firm quote before authorising a repair, as it can cost more than the machine is worth.
Jan 09, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K 3.97M electric presuure washer cycles on/off.
Hi;
It has an internal water leak or a seal or valve is leaking air. These machines are warrantied for 2 years and that is about all you can expect from them. Having it repaired professionally would cost about 75% the price of a new machine. If you are handy enough to get into it yourself, e-mail me and I will send you a diagram. (firehead@rogers.com) Part prices are expensive in Canada but not bad in the US. I don't know about other countries.
Sep 09, 2009 | Karcher K2.26 Electric Power Washer
I have a K3 78M electric unit . The motor pulsates
This sounds like an internal leak. If you are handy enough here is a schematic. On B@ it could be #25 is sticking or the valve inside #8 is leaking or the water seals #18 need replacing or #1 is leaking
Aug 18, 2009 | Karcher Garden
Runs constantly and leaks water from the housing
There is an internal leakage or breakage. This will cause a leak and also cause it to keep running.
Jul 03, 2009 | Karcher K2.26 Electric Power Washer
Karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K3.68MR Electric Pressure Washer Logo
46 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
