I have problem my a/c unit condencer i would like to know what motor fan has to install itsself in my unit because they put the rong one in it and i would also like to know what type of capaciter the model # is scu13h42 A -1
    Scholar:
  • 133 Answers
This needs to be a general answer, for information only, and not meant to be a full solution. Every motor manufacturer makes models for general replacements into many different applications. The capacitors are NORMALLY 5.0 Microfarad, 370 volt or 7.5 Microfarad, 370 volt. They are called ELECTROLYTIC types and are unique in being oval shaped cans. The ratings mentioned are stamped into the metal can.The motor type and specifications depends on what Make and Model unit you have. In some of the 60s and 70s condensers, they ran at 825 Revolutions Per Minute (RPM). Some at 1175, some at 1725 and in the newer equipment, they can be multi-speed or even variable. What is wrong that you think it is the wrong one? Can you please include the Make and Model numbers of your condensing unit in your response so I can look it up. Thank you for writing us.
Roger
Posted on Apr 03, 2011
Condencer fan stops
bad capacitor or motor.
Apr 08, 2014 | Bryant Heating & Cooling
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
I have a Fujitronic FH-700B Portable A/C unit that is squealing when I press the Cooler button. I can't find any help or support online as the item is no longer sold - is there a manual or...
SOUNDS LIKE THE MOTOR NEEDS OIL...LOOK FOR ZOOM OIL THIS LITTLE GUY IS A LIFE SAVER.. IT COULD ALSO BE FAN HITTING SHROUD, AND WILL CURE ITSSELF OVER TIME, BUT A OLD UNIT I THINK NEEDS THE FAN OILED..HOPE I WAS OF HELP. HIT THAT YES BUTTON IF'N I WAS .. JAY MOTOR GUY
Jul 21, 2011 | Fujitronic Heating & Cooling
I have a bryant AC/heat pump unit. Today I noticed that the air coming from the vents is just warm air, so i went out and the unit in not running condencer nor the fan. (it is the 661cj030-e unit).the only...
YES. It seems your capacitor is bad.
It must be replaced with the exact specifications as the original.
IE: MFD and VOLTAGE for the compressor and fan motor.
Example...35+5 370 vac.
Jun 27, 2010 | Heating & Cooling
I have a Ruud Heat Pump system. The outside unit makes a humming sound in either heat or cooling modes. The fan won't come on. In cooling mode, the compressor starts up, but them shuts off after about a...
Sounds like your condencer fan motor is stuck. Can you take a long rod and when the power is off to the outside unit, spin the fan blade? Maybe it will be enough to get it working again.
Apr 07, 2010 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Condencer unit fan wont run
If you have power to the fan and the fan won't come on, then its bad. You don't have to do another check. You will know if the capacitor is bad by turning the power on to the unit and taking a stick to start the fan. If the fan starts running after manually spinning, then the cap is bad. If not, the motor is bad.
Apr 02, 2009 | Heating & Cooling
MAYTAG SIDE BY SIDEM CONDENCER FAN NOT WORKING<ALSO LEAKING,FREZZER KINDA COOL,,,FRIDGE NOT
check and make sure the condenser fan motor is electrically connected. Some units have a plug that plugs on to the motor. Make sure it is plugged onto the motor. Will the fan blade turn with no resistance? If there is any resistance the bearing in the motor is dry of oil. Most are sealed bearings and the common practice is to replace the motor. I have oiled these sealed motor bearings in the past and brought the motor back to life. I don't know what type of motor your system has as you did not give a model number .
May 03, 2008 | Refrigerators
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
