Question about Danby DDW1899BLS Builtin Dishwasher
I have check water inlet and drain all are clear and working. when i go to run a cycle it turns on but then a couple minutes in it stops and beeps and displays E1. Now there i water left in the bottom of the washer, i tried to run a second time and same thing happens. suggestions? the dishwasher is only 2 months old.
    President:
  • 2,468 Answers
Where did you purchase this unit???, at 2 months,i would consider contacting the company and have the installer remove (per the companies guidelines pursuant to warranty work ) this (NEW- 2 month old unit) and have them pay for a compatible replacement or an exact replacement FREE of charge, instead of trying to find the issue on your own and possibly VOIDING your WARRANTY on a new 2 month unit
Posted on Apr 03, 2011
My washer is running the water in. Before it washes it starts to beep. The only way to get it to stop beeping/wash is to hit Power which of course drains the water. The clothes are full of water so I have...
The computer might not have confirmation of a full tub of water n the alloted time. Their could be some junk in the water level pressure tubing. Take the top off and remove the hose. Blow it out to remove any sedement that might be in there. Won' cot nothing to try. The flow meter measures the amount of water a goin in and when the computer thanks the water in their is anuff then it needs ta get a confirmation from that pressure in the tubing. if you got some junk in there the brains won't get that confirmation and the whole shebang will come to a screachin halt for fear of floodin.themobilian_500.jpg
My notes:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
Your tech sheet is located behind the base panel. The handy hippy has made a nice video HERE
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Takes long time to start washing cycle, makes groaning sounds as it gets started, then barely into process it beeps and flashes "f" and "h" alternately.I noticed that when I tried the "rinse/drain" cycle...
F/H" No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
  • Check CCU operation
Aug 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f 21, what does this mean?
The error code F-21 refers to Long Drain. The washer has sensed that it has not drained out completely and cannot go into further cycle.
If yours is a HE 2 washer, afer few minutes, Sd error will be displayed and then after couple of minutes F21 error code will appear. Water valves will be turned off and stops running.
If yours is a HE front load, when drain time exceeds 8 min, F21 error will be displayed. The water valves will be shut off and pump will stop running.
Generally, by re-storing the power to washer, it may fix the problem.
You may press the pause or the cancel button twice to clear the display.
You may have to double check the drain hose to see if there are any kink, clogs.
Also, you may unplug your washer, turn the circuit breaker off for 1-2 minutes and then plug it back in to check if it works. After this, check to see if the washer drains.
May 18, 2010 | Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Duet clothes washer will work for the first 7 minutes and then F20 (Water Inlet Problem) flashes. I've tried unplugging it overnight and that didn't help. It's getting water fine during the...
F20
NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED. The pressure switch is not tripped after 6 minutes. Possible Causes/Procedure If there is no water in the unit: – Make sure that both valves at the water source(s) are turned on all the way. – Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. – Verify inlet valve operation. If there is water in the unit: – Verify drain pump operation. – Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Press PAUSE/CANCEL twice to clear the display. The machine will drain for 3 minutes before unlocking the door. 3. Unplug washer or disconnect power. 4. Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU). 5. Check all hoses for possible leaks. 6. Plug in washer or reconnect power 7. Verify pressure switch operation. 8. Verify CCU operation by running a Diagnostic Test or any cycle.
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Letters H & F start flashing mid cycle which stops the cycle
error code  -----  F/H ----------- reason ----------- No water detected entering machine or Pressure switch trip not detected.
Or
solution to resolve  -----------   Press PAUSE/CANCEL twice to clear the display.
    3. Verify inlet valve operation
    1. Verify Drain pump operation
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Mar 14, 2009 | KitchenAid Washing Machines
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
F-H code and water won't stop
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Verify CCU operation
Nov 27, 2007 | Kenmore Elite 45986 Front Load Washer
Danby DDW1899BLS Builtin Dishwasher Logo
105 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
