Question about Pyle PLA2580 Car Audio Amplifier
How to adjust my amp - Pyle PLA2580 Car Audio Amplifier
Laser tappets adjusting
Remove the spark plugs, Rocker cover ect, On a Four cylinder engine , when num 1 Piston is on the compression stroke & when it is at the top of the cylinder, if you rock the crank shaft pulley back & forth you will see the 2 rear num 4 cylinder rocker arm are rocking, so they are ready to adjust when you have num 1 cylinder at top of the cylinder, so do the opposite, get num 4 cylinder on compression stroke to the top of the cylinder & adjust the num 1 rocker arms, for num 2 & 3 you do the same thing, When a cylinder is at top dead center its opposites rockers are at their lowest point of the cam shaft & ready to adjust, Hope you under stand what i have written, Stephan
Mar 04, 2014 | Ford Vehicle Parts & Accessories
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
How and where do you adjust the synch on 1986 gsxr
I can help with this.
On the earliest models they had slide type carburettors. This is to say that the slides were actuated by the throttle cable acting on a linkage that physically lifts the slides in the carburettors. This type of carburettor has its balance(syncronization) adjusters under the caps on top of the carburettors.(the cap isn't round & has 3 screws in it)
Number three carburettor is fixed & dosn't get adjusted.
You'll have to put the bike next to a bench & attatch a long piece of fuel hose from the tank to the fuel hose on the carburettors.You can join the two pipes together using a short piece of hose that snuggly fits on the outside or inside of the two hoses. You can also join them with a suitable shirt piece of metal pipe,or what is called here in Australia a P3 barb.These are available from tool suppliers that supply air compressor hoses & fittings.
(I made a remote tank from an old lawnmower petrol tank,a long piece of hose & mounted it on a tall stand.Under it I have a tray with all my different adaptors in it.)
You adjust number 2 cylinder to the same vacume reading as number 3 cylinder first.
Now adjust number 1 cylinder to the same vacume reading as number 2 cylinder.
Next adjust number 4 cylinder to the same vacume reading as number 3 cylinder.
Recheck that they are all the same & your done.
The adjusters are of the screw & locknut(8mm)type.
You can struggle with an 8 mm ring spanner & a flat bladed screwdriver,buy an adjusting tool(genuine, or non-genuine from a bike shop) or make one.
To make one you weld a bar onto the side(at the top)of an 8mm extended quarter inch drive socket.Then find a long small screwdriver that will fit down the hole.
After you make each adjustment,stop the engine & open the throttle wide open & release a couple of times.(This seats the slide).After diong this re-start the engine & re-check your adjustment.
I place a fan blowing on the engine to help control the engine temperature as the adjustment can be a bit of a fiddle.
I prefer to use mercuary type vacume guages as they dont go out of calibration.
If you are using dial type guages check that they are all reading the same by checking them all one by one on the same cylinder.
Some Suzukis' have a pipe (covered with a black rubber stopper) at the top of each carburettor(at the front) & others have an allen screw on the cylinder in front of the carburettor manifold rubber.
If yours has the allen screw you will also need adaptors that screw into the hole once the allen screw is removed.
If you bike has diaphram type carburettors on it(you'll be able to recognise this by the top caps of the carburettors being black & roundish in shape & held in place by 4 screws), the adjusting screws are between each carburettor & are the spring loaded type.
The adjusters are located in-between each pair of carburettors visable from the top.
These are easier to adjust as there is no lock nut to struggle with & all you need to turn the adjusting screws is a long (flat or phillips)screwdriver.
Again, balance the center two first,then the left pair then the right pair.
This procedure is applicable to all in line 4 cylinder motorcycles (even most fuel injected ones.
Regards Andrew Porrelli
Nov 26, 2009 | 1986 Suzuki GSX-R 750 G
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
Automatic exposure adjustment
NP7161: we include - blazes "id"; what throw?
Necessary entering the identification number of the access; the unset: Head - ID - a foots - a head - (on дисплее will appear ID1) - 2 - a start - (on дисплее 2-1) - 0 - (on displey 2-0) - a start - (the codes of the users delete) - ID possible to copy.
NP7161 - a regulation AE
Adjustment AE: -User mode 12 - an the man picture, 12. then - a button "+/- exposure" (24 steps); "Start" - a taking the change
May 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Samsung SCX 6320F ADF adjustment
Press on button PROGRAM and hold its beside 5 sec. Hereinafter you the menu will be print on paper, you will be able to adjust. Hereinafter memory can be a loaded page for sending out or messages of the answerback, or writing the talk. This all are executed with управлениес with panels button to wipe and beside you are got by free-memory Good luck
Jun 03, 2008 | Office Equipment & Supplies
Pyle PLA2580 Car Audio Amplifier Logo
20 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
