Question about Refrigerators
Refrigerator and freezer not cooling cleaned everthing underneath and around compresser fans all running .
    Guru:
  • 257 Answers
Hello Earnedit03,
I understand that you are having a problem with you refrigerator not cooling at all. However, all of the mechanics are working properly. This issue will be a freon leak, this is not a DIY project as you must recover any freon (refrigerant), pull the unit down, find the leak and patch, and recharge the unit.
Is the unit worth repairing? You should call around and see what the cost of repair wil cost in your area. If the cost is above half the cost of a new unit, you are better off replacing than repairing.
Ultimately the choice is your as to what to do at this point.
Thank you for choosing FIxYa.com
Justin
Posted on Apr 03, 2011
Ice builds up in freezer than leaks out around seal
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 09, 2011 | Maytag Refrigerators
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Not sure of the model or make, but the freezer and refridgerator work and then dont work, i can freeze water but a day or two later it's thawed?
First, make sure the refrigerant coils underneath the unit are not dirty. If so, clean them off.
Second, make sure the compressor (underneath the refrigerator) is running.
Third, make sure the compressor fan (underneath the refrigerator close to the compressor) is turning. This fan should always be turning when the compressor is running. It removes heat from the refrigerant coils and transfers it to the outside.
Fourth, make certain the evaporator fan (in the freezer, likely behind an access panel) is turning.
All of these conditions must be present for proper cooling.
Oct 20, 2009 | Freezers
Our fridge and freezer are not cooling, and the fan is not running. I cleaned underneath, and even used compressed air. It came on for a day, but has stopped again. It is an Inglis
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fhjf
Jul 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Warm fridge
how is the freezer side check theese and get back to me hold the rating till we are done is the freezer fan running as the freezer cools both sides is there heavy frost on the back wall of the freezer down toward the bottom is the compressor running is the fan that cools the compressor running are the coils underneath the unit clean is the ice cream to soft milk too warm
Mar 02, 2008 | Amana ASD 2624 Side by Side Refrigerator
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
