Question about Cuisinart Coffee on Demand 12-Cup Coffeemaker
I have a Cuisinart COD 4000BWSA and it no longer turns on..it just stopped working one day..any suggestions? Thank you
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart cod-4000 powers up no brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
SOURCE: Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Posted on Oct 24, 2010
We have a 2 year old Cuisinart COD 4000 series. The unit will no longer starts. We put on brew cycle and turn knob to on. Light comes on. Hear a click but it does not brew anymore. Have unplugged unit...
I just had the same exact issue, call cuisinart customer service and they'll replace it. The unit has a 3 year warranty, I had no receipt or anything and they are sending a new unit, all they ask is that I cut the power cord off of the old one and send it in.
Aug 07, 2010 | Cuisinart Programmable 12-cup Thermal...
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Jul 15, 2009 | Cuisinart Coffeemakers
Coffee pot will not turn on ? about year old cuisinart cod-4000
I am having the same problem. All the sudden my coffee maker will not work. Called Cuisinart customer service and was told to try to unplug for 2 hours to see if it will reset. They will offer a replacement on 3 year warantee, but they are back-logged and will not say when the replacement will arrive.
Jun 07, 2009 | Cuisinart Coffee Makers & Espresso...
Cuisinart DCC-1200 won't turn on
Yep. Unplug for 20 minutes or longer officially. If it doesn't work, your serial number may still put you in warranty. They have a longer warranty period than anyone.
Jan 02, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart cod-4000 powers up no brew
-Tha Mp3 Doctor
Dec 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart dgb-500 automatic grind & brew
-Tha Mp3 Doctor
Jun 11, 2008 | Cuisinart DGB-500 Coffee Maker
It just stopped working
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Oct 29, 2007 | Cuisinart DLC-10S Pro Classic Food...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
