Question about Craftsman 24 Hp 48" Deck Yard Tractor
I need to remove the electric clutch from my Craftsman 24 hp 50" mower (Model No. 917.273220). When I try to unscrew the bolt from the clutch the whole drive shaft turns. How do I keep the shaft from turning? I took off the plastic screen on top of the motor and tried to stop the drive shaft from turning by putting on a wrench and holding it. All I did was unscrew the bolt. Any ideas?
  • Joseph Tanner Apr 04, 2011
    There is not a lot of room for a pipe wrench. I can barely get a set of pliers between the pulley & the top of the engine. I guess I was expecting a more standard solution to get the bolt off of the bottom of the clutch. Isn't there a more formal (easy) way to immobilize the drive shaft?
SOURCE: Craftsman mower
charge the battery sometimes they come not fully charged if not push down clutch/parking brake sit on seat becouse of dead man switch and then crank it over
Posted on Sep 26, 2008
wadembly
  • 448 Answers
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Posted on Jun 14, 2009
  • 376 Answers
SOURCE: How do I remove the spindle from the deck of a Craftsman mower.
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Posted on Jun 15, 2009
  • 376 Answers
SOURCE: Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
  • 138 Answers
SOURCE: engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Posted on Aug 24, 2009
Where is the PTO switch?
The switch is on the dash bezel, the electric clutch is on the deck. Some clutches can be adjusted but I need the model number of your mower first.
Jul 06, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
How do I replace the Blade Clutch Assembly on a Craftsman mower, model 817.288160?
There is one bolt in center of pto clutch. Its best to have an impact to remove this. If you try to remove with a wrench engine will spin. Remove both belts first. Then simply unplug the PTO, Use impact wrench and remove center bolt and gently pry off. Installation is the reverse order.
Oct 15, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
Our 24 hp GT 5000 cutsoff and blows a 30 amp fuse when the mower is engaged. Does anyone have a solution?
The electric clutch is shorted out or defective. More than likely you will need to replace it. Check all the wiring for a short before proceeding.
Jul 02, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Turn off mower blades the electric clutch spins and the two green
There should be a metal "anchor" that bolts to the chassis or engine. It has a rod that sticks downward, fitting into a notch in the clutch to keep it from turning. It must be missing or broken, or maybe the clutch is the wrong model, and that's why the clutch itself spins and rips out the wires. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
How do I remove electric clutch pulley on Craftsman 917.257720 lawn tractor?
if i'm not mistaken there should be a bolt in the center of the clutch that screws to the crankshaft remove top cover and have someone hold a wrench or socket on the top nut while another unscrews the bolt running through the clutch (righty tighty lefty loosey) may need to unbolt the steel rod that keeps the clutch housing from spinning. also dont forget to unplug the wires hope this helps
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
102 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
