Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I had a power surge and am now getting a blank screen on my RP2100 appears I fried my transformer since I am getting 0 from it in dcv.
    Problem Solver:
  • 20 Answers
It's ACV on the two yellow wires going into the main circuit board.
Posted on Apr 04, 2011
Power surge and thermostat has nothing on screen
Check battery's , & try inturepting power for 5 to 10 min,if no response
change ,24 volt transformer or control .
Feb 25, 2013 | Lux Thermostats DMH110 Digital Heating and...
HEATER SHUTS DOWN AFTER ABOUT 20 MIN. AND THE DIGITAL BOARD GOES BLANK
bad transformer overheating when it does it check voltage from transformer if none or low replace
Aug 02, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
The touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
Re: the touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
No there is not. If the touch screen is blank and you know that you have power at the outlet, then the computer module has been fried and will need to be replaced.
Possible reasons for a computer module going bad are most commonly due to power surges. If you plug in an outlet surge suppressor then plug your computerized washer and dryer into it, that will save you BIG $$$ over time.
May 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Heater will not heat to set temperature and board goes blank
bad temp sensor or transformer if voltage coming out after it goes out bad board if no voltage bad transformer
May 12, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
Blank no video
Replace the Capacitors in the power supply. Start by replacing the two 1000 uF and two to four of the 470uF. Make sure you replace them with computer grade replacements i.e 105c temp rating and it doesn't hurt to up the voltage either.
This will usually do the trick. If not, you may have a burned out CCFL or one or more of the driver chips that drive the transformers is toast. Lastly there is always the possibilty of a shorted transformer.
Good Luck!
Feb 29, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
LIghtning power surge fried transformer
I would call the insurance company first, the set will never be the same.
Dec 03, 2007 | Toshiba 57H82 57" Rear Projection...
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
96 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
