Question about Brinkmann 810-2300-B Grill
Low flame after winter non usage. All burners light, but low flame. Need to be cleaned? New regulator, fill tank?
    Brigadier General:
  • 4,736 Answers
Could be a low or empty tank. But, I suspect if the tank was turned OFF all winter and you just turned it ON, the tank's OPD Valve has lcked up you grills regulator. To test this theory, turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank and turn it to it's highest setting. Does the flame height now appear to be normal. If so, light the remaining burner(s) the same way. If everything has returned to normal, you've solved the problem. If it hasn't, then more thank likely your Propane Tank is empty.
Hope this helped you solve the problem
Posted on Apr 03, 2011
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
I have pyromaster gas logs that has low gas flow
Sounds like a ventilation problem... they're not getting enough air. That's a real safety problem. Make sure they have enough fresh air, and that the room itself does also. This issue is a major safety problem, and if more ventilation does not fix the issue, stop using it! Gas burners are not supposed to stay on without a flame present!
Apr 12, 2017 | Heating & Cooling
Low flame at burner. I've put a new tank on my grill and now the flame stays very low on all burners. I've heard that there can be some pressure problems with a newly filled tank. Is there a quick...
Mike, there can be some pressure problems, but it's not the new tank. However, it does cause the problem and here's how you resolve it.
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn the burn to HIGH.
Does the burner light and the flame height look correct? If so, light the remaining burners the same
way. Now, do all the burner flames look as the should? If co, you solved the problem. Always
remember to turn the tank valve ON very, very slowly>
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can pick one up at any home center or hardware store that sells gas grills and accessories. It will run you about $30.00 (+/-) .
Hope this helped you to solve the problem Please let me know & Happy Grilling!!
Jun 12, 2011 | Grilling
A low flame comes out of my burners. I can not make any adjustments to make it hotter.
Unless, your tank not is really low on gas and your burners really don't need cleaning? Try this:
Turn OFF the tank valve and disconnect the hose/regulator assembly from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow), until the tank valve is fully open. Then light the burner farthest from the tank and turn the control knob to the highest setting. Has the flame height returned to normal on that burner? If so, light the remaining burner(s) the same way. Now, do all the burner flame heights look normal? If so, you solved the problem. Just remember to always turn the tank valve on very, very slowly.
If the above didn't solve the problem, turn the tank valve OFF. Disconnect the hose/regulator assembly from the tank and the grill. Then, head on over to your nearest home center or hardware store that sells gas grills and accessories, because you need a new hose/regulator assembly. Be sure to take the old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem.
Apr 29, 2011 | Char-Griller CharGriller Grillin Pro 3001...
Grill does not get hot enough. Which seem like low gas flow. One burner does not light
Yes, it is probably low gas flow. I assume you feel comfortable that there's a reasonable amount of gas in the tank.
Here's what you need to do. Turn OFF the LP Tank Valve and disconnect the hose from the tank. Wait 5 minutes. While you're waiting lift out the tank. Does it feel as heavy as it should? Or does it feel lighter than it should? If it feels lighter, you're either very low or have run out of gas.
In either case, here's what you need to do when you reinstall that tank or a new one. Attach the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY ( I'm talking slow motion). Once the valve is fully open, light the burner that's farthest from the tank and turn it to the highest setting. Does the burner flame look correct? If it does, light the next burner and turn it to high and continue doing that until all the burners have been lighted. If the first burner flame doesn't look correct after you lit it. Turn the tank OFF and repeat what you did previously. If it still fails to produce the right flame heights, either the venturri valves on each burner are clogged or the regulator is locked up.. You will have to remove the burners to clean them. If that fails to solve your problem, buy a new grill hose and regulator. You can purchase it at either Lowe's or Home Depot or your local hardware store. Just be sure to take yours with you, so that you can get the right length and brass fitting size matches.
I'm sure this will solve your problem. Please be kind enough to let me know.
Happy Grilling
Rich
Mar 04, 2011 | Char-Broil Advantage 463453306
My 1100lp when burners are on low flame is to low and make squeeking noise and if a slight bit of wind will blow out flame. I cleaned burner tubes and replaced regulator with factory parts will heat up on...
turn off the LP Tank, disconnect the hose from the tank and wait 5 minutes. Reconnect the hose and turn the tanl valve on very, very slowly, until it's fully open. Light each burner and turn it to high. Wait for the burners to heat up and turn them down gradually to low. If flame height on low has returned to normal, the problem is solved.
If that didn't solve the problem, the air shutters on each burner may need adjusting. Consult the installation instructions that came with the new burners for the proper setting or consult your Owners Manual.
If it's real real cold outside, it's not unusual for the burners set on low to have a problem. The only solution to that is let the grill preheat well, before turning the burners down. Also, grill with the hood closed on low, if it's a windy day.
Hope this helps you and gets you back to grilling again.
Feb 11, 2011 | Weber Genesis Silver A Grill
I have a full propane tank. I bbq'd about 3 weeks ago, same full bottle. Grill will not light. Good spark at ignitor. Used lighter and lit for a few seconds with low flame on high. No other burners will...
You may have turned the gas tank valve on too fast. Turn it back off, disconnect it and reconnect it. Then very slowly turn the valve back on. Light one burner at a time and turn to low before lighting the next. If you are hearing and smelling gas with the tank on but all grill knobs off, don't use the grill. You may have a leaking grill valve, regulator or hose. If you are only smelling gas with the knobs on, it's possible you have a clogged burner or orifice from bug nests, spiderwebs, etc and need to clean it out first. Hope this helps. Douglas
Jun 13, 2010 | Brinkmann Charmglow Stainless Steel LP...
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Very low flame, like very little gas is getting thru, tank is ful
Okay, what you are dealing with is called "vapor-lock". The way these grills need to be turned off is, close the tank valve first and after the burners go out, then turn the burners off. The way you are doing it is trapping the gas and you are getting a weak flame. Fortunately this is an easy fix. First, light the grill by turning the gas valve open, then turn the burners on to light the grill...as soon as that is done, close the gas valve on the tank then turn the burners off. Repeat this procedure until you get a good flame. If this procedure hasn't fixed the problem after the third time, you need a new regulator and regulators are easy to find in any home improvement store like Lowe's or Home Depot.
Dec 15, 2009 | Weber Genesis Silver B Grill
Brinkmann 810-2300-B Grill Logo
340 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
