Question about Hampton Bay 44 In. White Carousel II with Multicolor Blades Fan
I bought a house with hampton bay fans and used a different lighting kit and hooked blue and black wires together and white to white wires and plugged connector back in and light kit will not light and cannot figure out how to remove the fan from ceiling to check wiring from house. the fan part works.
  • 37 Answers
If you have the fan working are sure there is not a light switch some where in th room that goes to the light side of the fan.and the chain for the light will have to be pulled to on also.is it a remote control fan that would have a remote that has been lost.some fans have a little black box in them that is a radio cntrl.you should be able to remove the fan with a few screws at the base next to the ceileing.be careful they can be heavy.
Posted on Apr 25, 2011
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Sep 10, 2010 | Hampton Bay 24002 Ceiling Fan
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
When I hook my Hampton Bay ceiling fan to power, neither the fan nor the lights work. I have power to the fan and have the black and blue wires on their own power. I show power to the light socket but no...
OK .. if you hooke the bnlack and blue fan wires to the black and red house wires , then that is set for the hook up .. Now at the switches ,, you should have two switches ,, black on the switch for the fan and red on the switch for the lights .. the switches should both be connected to the hot power wire ,, Check for the neutral connections ,, in the switch box all whites would be connected together , and white to white in the ceiling
Please vote
May 13, 2010 | Hampton Bay 24002 Ceiling Fan
I have a hampton fan 5 blades, is the proper way to connect for the lights to is to connect the blue wire to the white wire or the black wire
If you nare adding a light kit to the base of a ceiling fan, you will connect the blue and black wires together ,, and then the two white wires ..
May 04, 2010 | Hampton Bay 24002 Ceiling Fan
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
My fan has three wires, black white and blue. It had no manual and I wonder how to wire it to the on/off switch.
Put the black and blue wire together with the black wire on ceiling. Put the White with the White wire on ceiling. Bare/green wires are ground put them together.
What fan wires do.
The black wire is to power the fan motor.
The blue wire is to power the light on fan.
The white wire is neutral.
If you wire this way you turn on the switch and use the pull chains to control the fan and light.
You can also buy a remote control unit at a home depot. And it will have instructions on how to hook to fan and ceiling.
Jan 02, 2010 | Hampton Bay 52 In.Carriage House II in...
Wiring problems
The only thing which goes to the house's white wire is the fan's white wire.
Both the black and blue wires from the fan (black for fan motor, blue for light kit) go to the black house wire.
Anything else could result in a fire, a melting of internal parts, or a massive electrical explosion arc. The owner's manual is very clear about how the fan is supposed to be wired, and you voided the warranty by going against it.
You may have blown a fuse or a circuit breaker, or you may have blown something within the fan, or your house may be wired in series (very unlikely) in which case you need a new separate wire run for the light kit.
I hope this helps! If you have any other questions, feel free to ask!
Apr 17, 2008 | Hampton Bay 24002 Ceiling Fan
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay 44 In. White Carousel II with Multicolor Blades Fan Logo
82 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
