Question about OKI C5100n Laser Printer
OKI C5100 Making grinding noises
Hi;
We have a OKI C5100 at our church. It's run fine for several years, but all of a sudden, started making grinding noises from within, and then flashed 540 and 541 errors. I cleaned the opticals for each of those drums, and even cleaned out all the old toner and made sure the gears on those would turn, which they seem to do. This made no difference; still get the grinding and error codes. I reset the counters on all consumables, still no diff. If I had to guess, I'd say the sound is coming from the unit under the transfer belt that has several optical sensors on it. When the gears near that unit are turned, the back of that unit slides toward the fuser, exposing the opticals, and when it gets what appears to be close to the end of its travels, that little sliding part pops back and forth as if it is stuck and a hear a little click - Not positive this is it, but best I can see! I don't know anything about these, but I'm a pretty savvy repair guy - Is this something I can fix?
  • trinityops Aug 06, 2008
    Thanks Wayne - I did both of those fixes, no diff, I'm afraid - Wish I could determ,ine for sure what that grinding is...
  • judyh12 Dec 19, 2008
    After reading this post I experimented and indeed the grinding or "clicking" as I called it in my last post is coming from the unit under the transfer belt that has several optical sensors on it that when explosed at the end of the gears complete causes the sliding part to pop back and forth as if it is stuck and thus making the clicking noise. What is the reason and the solution for solving this. Anyone?
  • 300 Answers
Click the following link, it should solve your problem
http://www.fixya.com/support/t238726-sensor_error
Regards Wayne
Posted on Aug 06, 2008
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
Loud grinding noise within the engine and stalling after braking hard
Flex plate is cracked. That is another reason it stalls.
Nov 08, 2011 | 1996 Eagle Vision
When printing on my oki c5100 text or image - it prints fine but with a smudge/ghost of the image or text also on the paper. I know I need to order new toner - could this be why?
Open you printer and pull out the fuser assembly and look if the upper roller is fine because if it`s damaged it could lead to the double image.
Oct 20, 2010 | OKI C5100 Laser Printer
The drum all of a sudden started making making grinding noises, took out several dollars of change and other stuff, now drum will will not turn, belt seems fine, heat fine
Make sure with a manual movement of the hand that the drum is rotating and the motor is free.
now when the drum was struck did it cause any errrors in the motor orr the control board or a fuse tobeblown.
so checkthis out if the drumis free and the motor is not getting supply from the control board.
Check the safetydoor switch to latch for the unit to work, check if any wires were pulled off while you repaired the drain to cleanup.
Sep 30, 2010 | Kenmore Dryers
My oki C5150 is making a clicking noise in the front like the sound of a playing card in a tire spoke when riding a bike. ( i used to do this when I was a kid )
I had this problem with my C5100. In addition to the noise, it would not print. It turned out that it was the black drum and I replaced it. The noise went away and I could print. I have since found out that there is an internal counter that disables the drum after it gets to a preset number of copies. I searched for and found instructions on how to reset the drum counter in advance of it "self-destructing". It may be too late to do this after it starts clicking, but it can be used in the future.
Sep 17, 2010 | OKI C5100n Laser Printer
LG dryer was making a squealing noise, then suddenly started making a loud noise like gravel was being rolled around in the drum. Could this be a broken belt?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dfhjdg
Aug 03, 2010 | LG DLE5955 Dryer
I have an oki c3530 and it is making a terrible grinding noise, any ideas?
One of the drums needs to be replaced. Systematically remove one at a time until the grinding noise no longer happens, then replace that drum.
Jan 26, 2010 | OKI C3530N Color MFP Printer
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Grinding noise on OKI C3300
I have had a similar problem. . Black drum needed changing. There was also a grinding noise developing. I have taken each drum and toner module out of the printer and booted it up with one of the 4 missing. It was the Cyan drum that was making the noise. . Question is what can I do? I am not a printer expert. .
I will contact the local printing shop that I use for more info and will come back to you. I suspect that I will need a new drum . . .
Nick Smith
nick@selectaccountingservices.co.uk
Nov 28, 2008 | OKI C3400n Laser Printer
Oki C5150N Grinding noise
One of the drum cartridges is stuck. Test by removing them one at a time with the printer off, then turning on.
Oct 31, 2007 | OKI C5150n Led Printer
OKI C5100n Laser Printer Logo
578 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
