Question about Sharp EL2630PIII Calculator
Need a paper roll holder Sharp EL-1197GIII - Sharp EL2630PIII Calculator
  • 168 Answers
SOURCE: where do i put the paper into to replace a new roll
There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
Posted on Feb 04, 2008
dragonsthatk
  • 547 Answers
SOURCE: Calculator paper roll change, How to?
feed paper throught bottom to top hold down paper feed botton
Posted on Feb 12, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
RonPark
  • 855 Answers
SOURCE: Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Posted on Sep 26, 2009
SOURCE: sharp caluulator EL-1701C out of ink..lost manual
found solution. thx.
Posted on Nov 16, 2009
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you put the adding paper into the machine? My machine is a EL-1197iv
    Never insert paper roll if torn. Doing so will cause paper to jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig. 2)
    3) Insert the paper roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Jan 03, 2011 | Sharp EL-1197PIII Calculator
    Will not feed paper
    PAPER ROLL REPLACEMENT
    jam.
    (Fig. 1)
    2)
    3) Lift the attached metal paper holder up and insert the paper
    Dec 19, 2010 | Sharp EL-1801AII Calculator
    How do you put the adding machine tape into the Sharp EL-1801V Adding machine?
    Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
    Mar 08, 2010 | Sharp EL-2630P Calculator
    Sep 26, 2009 | Sharp EL-1197PIII Calculator
    Ribbon installation
    I searched this online, and have found the following instructions:
    1) Set the power switch to OFF
    2) Remove the printer cover
    3) Remove the ink roller by turning it counterclockwise and pulling it upward.
    4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
    5) Put back the printer cover.
    May 30, 2008 | Sharp EL-1801P Calculator
    Tape wont register on this after we changed the tape
    Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
    1. Lift the paper holder up.
    2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
    3. Insert the paper roll from the left side of the paper holder and make sure the paper
    roll is set in the proper direction (with the paper feeding from the bottom).
    4. Insert the leading edge of the paper into the opening directly behind the print
    mechanism.
    5. Press the paper feed key and feed the paper under the edge of the paper cutter.
    Dec 07, 2007 | Sharp EL-2196BL Calculator
    Sharp EL-2196BL
    mechanism.
    Sharp EL2630PIII Calculator Logo
    54 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
