Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
My 42" toro zero turn
The drive belt pulley probably needs replacing or the belt popped off the pully
Posted on Aug 08, 2012
2 Suggested Answers
  • 539 Answers
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
Try http://www.manualowl.com
Posted on Apr 13, 2012
My husqvarna zero turn 54 inch will not go forward or backwards. Mowed went to put up and just stopped.
Hydro units usually do not suddenly stop. Check your drive belt on the Hydros. When a Z mower stops suddenly, it is usually the belt or idler pulleys.
Sep 04, 2017 | Husqvarna Garden
I have a toro zero turn z4200 starts and runs fine but when I put arms in gear, it will not move forward or backward.
Make sure the drives are engaged. Under the seat and towards the rear are two thin metal levers with finger loops. These are used to disengage the drives in order to push the mower when the engine is off. Levers towards the back to engage.
Good luck
Mar 30, 2015 | Toro Garden
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
When I go forward the handles are not even, pulls to the right
there should be a adjustment on the linkage or a stop for each handle
Apr 21, 2012 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Toro Z5000 won't move
did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Was mowing and the mower wouldn't let me move forward backward left or right. I walked behind the mower and found a coil with a hook piece underneth. Bought a new coil but don't know where it goes....
sounds like the hydro release rod, at back bott of mower, what this does is releases the hydro so you can push the mower around, then you have to release this and then your hydro works
Aug 02, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Go in reverse
The steering levers control all movement on a zero-turn mower. Just slowly pull both handles back evenly and you'll go backwards in a straight line. The farther you pull back the levers the faster it goes backwards.
May 17, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
1,103 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
