SOURCE: I recently purchased a Sears Craftsman Contractor
I can send you a manual for a Sear 6 1/8" jointer planer. Model number 113206931 if it will help.
SOURCE: Sears craftsman 6hp chipper-shredder FLYWHEEL.
Go to Lowe's they will found the part for on the computer and will tell you where it is at in the store!!
SOURCE: manual for Sears Craftsman Home Sharpener 19071
my bet is you need to replace the belts, I posted the belt info. http://www.bobvila.com/BBS/Craftsman_Sharpener_drive_belts__out_of_stock_sure-Tools-1-F909.html#2827
part number 100XL037 1/5 pitch (XL) timing belt
you will need 2 of them, price was $4.21 a belt
very easy to change out 1 on a scale of 10 for difficulty. you have to know how to operate a screwdriver.
shipping was $6.68
phone is 951-677-7424 www.surfrainbow.com in California
SOURCE: I have a sears craftsman 580 751 651 and after a
Hi Dave
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
SOURCE: Throttle cable is loose from engine; where does it go?
Sears has thousands of illustrated parts breakdowns on their Parts Direct website that can be very helpful in solving this kind of problem.
Along with their house-brands, they also have most other major brands available too.
Give it a try:
Sears Parts Direct
Testimonial: "This was a very good lead as far as getting an answer to my question. It did not solve the problem, but it gave me a good start."
Is this a throttle cable or a brake cable (also called a control cable)? For your unit the Sears breakdown does not show a throttle cable. It only has a Control (brake) cable, and a transmission cable. Answering this question will help to give you the best advice possible.
