Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
Where is the Hydraulic pump located in my JD 6400?
  • John Deere Master
  • 2,478 Answers
Posted on Feb 06, 2012
2 Suggested Answers
  • 3 Answers
SOURCE: Have a JD 2010.When engine is cold, the hydraulic
Look in front of the right hand side step, there is a round door with three bolts on the side of the transmission case, drain the oil first from the drain plug underneath.Remove the bolts and lever the door off, be careful there is a spring behind,the filter is a wire mesh type cartride and has a small wire handle to pull it out . wash the cartridge in solvent and blow clear with compressed air. Make a new gasket when reinstalling and use lots of Gasket sealant.
Posted on Nov 18, 2010
What causes the hydraulic pump drive shaft t22915 to break on my jd 2640 tractor
failed pump gears or relief valve not operational
if the gears are badly worn or the idle gear shaft is worn , the teeth will bind or jam in the housing
if the relief valve is faulty , the oil has nowhere to go so it locks the gears resulting in broken shaft
Sep 13, 2017 | Garden
My John deer 8r tractor it restricted my power. So I changed the hydraulic filter. And it still restricts the power. Why?
Be sure your flow control knobs are adjusted fully on. Check your couplers be sure they match with what JD recommends. You may have to get you local JD dealer to flow rate hydraulic pump and see whats going on.
Nov 18, 2016 | John Deere Garden
Where is hydraulic temperature sensor on John deer 6400
its in the side of the hydraulic oil storage tank , its job is to open the pass thru valve on the distribution block to allow for oil pass thru to heat oil in cold weather , when activated most of your attachments and steering wont work till oil comes up to temperature and bypass valve closes
the older tractors had just a pull on tab that the operator would have to operate to do this same function
Nov 17, 2015 | Garden
A WING ON THE JD 15' MOWER WILL NOT LOWER. ANY IDEAS?
Just an idea but my guess is that it is in the hydraulic system.
Probably a safety valve that prevents it from falling in case of a hydraulic line break.
Link to JD answer center.
Answer Center from JohnDeere
Sep 09, 2014 | Garden
Where are hydraulic filters located on jd 2030 diesel tractor
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Aug 24, 2012 | John Deere Tractor Side Screen...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Need a rebuild kit for the hydraulic cylinder that lifts the snowblower - does such a kit exist and what is the part number?
there are rebuild kits for some but not all, check your local jd dealer, my family ownd a jd dealer until last year jd stuff aint cheap. personally id type hydraulic cylinders into google and buy a replacement
Nov 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
JD 2510 hydraulic pump
sounds like some thing stuck in the cylinder i would tear down and inspect
Mar 17, 2009 | Plumbing
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
778 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
