Question about Hitachi Hdt721016SLA380 SATA II Hard Drive
My hard disk is Hitachi HDT721016SLA380 SATA Device, i have some trouble with bad sectors in my HD, i try to use HDD regenarator to fix it, but it seem not solve my problems. it steel having bad sector and i almost give up, please help me to solve this problems because all of my data is in the Hard disk and i don't want to loose all of it.
    Guru:
  • 382 Answers
Thank you for choosing FixYa!
Regarding bad sectors, unfortunately it cannot be fixed at all. For a more detailed explanation kindly go to http://www.fixya.com/support/r8119855-fix_bad_sectors_hard_drive.
I hope it helped.
Posted on Apr 03, 2011
How to repair samsung HD502HJ bad sector
No way. Try to make it shorter and cut off that area including bad sectors. Make a two partition around and enjoy!
Feb 11, 2014 | Samsung HD502HJ Hard Drives Sata-ii...
Error message says Hard Disk failure is imminent. Back up hard disk and replace.
You can't repair a HDD, only the MFG, and they put in a new disks and new head actuator.
You can run tests, check for bad sectors, try and repair bad ones.
You can do all this, then have it die and lose everything in time.
Buy a new HDD.
Newegg.com
You didn't post the model so I have no clue what your interface is.
It's either IDE or Sata.
Here is a Sata 3 HDD, 320g, 2.5 for laptops. 50.00 with shipping.
All Sata is interchangeable. If your chipset has a sata 2 you can put in a Sata 3 HDD.
Besides Sata 3 HDD are not really Sata 3 speed, only means it's for Sata 3 ports. No HDD can break the 200MB transfer speed.
If you don't know hot to tell what interface your HDD is post back asking with the moled number and MFG of your laptop.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152288
Apr 03, 2013 | Computers & Internet
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
Hi, How urgent is to change my HD while it already has 10 bad sectors ? HD name (as writen in the HD properties in the control panel) is: HITACHI HDS721025CLA382 ATA Device It's also described that it's...
This is not an urgent issue, it is normal for a hard drive to have bad sectors. When you consider there are billions of sectors on a typical hard drive, 10 is pretty insignificant.
Regards,
Gene Gilbert
Jan 20, 2011 | Hitachi Computers & Internet
Bad sector problem, and hdd is not working proparly, hdd ditecting problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
Nov 17, 2010 | Fujitsu 160GB 2.5" 7200rpm Internal Hard...
My computer HDD have bad sactors please help to remove this on
When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
SATA HDD not working
Avinash thaks for providing the exact error..
Re: A Disk Read Error Occured. Press CTRL ALT DEL to restart
1 - Have you tried a different IDE cable?
If not give it a go and do a repair if needed again!
2 - You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
3 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
4 - or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!! Good Luck D.i.l.i.p
Jul 02, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Biostar Motherboard p4m800-m7a
You may have a HDD Problem Diagnose it using the following. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 23, 2007 | Biostar P4M800-M7A Motherboard
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Hitachi Hdt721016SLA380 SATA II Hard Drive Logo
158 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
