Question about Kenmore Heating & Cooling
I just wanted to know if the heat &air window units use heat resistance com heat pump technology model#580.751245000
    Guru:
  • 257 Answers
Hello Turnbarfie,
If I understand your question right you want to know if the window units that have Heat/Cool air use the same technology as a heat pump. To answer your question yes they do. These units have a reversing valve that pumps the freon on way to cool and the other way to produce cool air.
Thank you for choosing FixYa.com
Justin
Posted on Apr 04, 2011
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Model 3812-972 MPPD-14HRN1-BH9
air conditioners are in effect heat pumps
that is they pump the hot air in the room via a gas to the outside area
when that outside are is still inside the room then that hot air is just recirculated
so if you want to heat your room the system is reversed so that you need the hot air outside pumped back into the room
the hot air is provided by the condenser which is now the evaporator in the room as the roles have been reversed so you will have to put the unit in a door way or use the ducting hoses to go out a window
Nov 03, 2015 | Heating & Cooling
Kennmore combo window unit will not blow hot air what could be the problem
That all depends on the model number of the unit you own. Some window units have electric resistance heat (like a toaster), where others are a heat pump. Even other models have heat pump ability, with added backup resistance heat.
Then again it could be a settings problem. Ifd the unit is not set in the right mode, and the thermostat is not set correctly, the unit may operate and not produce heat.
Jan 08, 2015 | Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Carrier OEM to Honeywell Programmable Tstat - NEED HELP
    you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
    Jan 27, 2013 | Carrier Heating & Cooling
    The clean light keeps blinking and won't run new cycle
    Whirlpool & Kitchen-Aid
    Tall Tub Dishwashers
    PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
    Control is programmed to stop running and not allow any further
    cycles if it detects a water heating problem (no temperature
    increase detected in heated Main Wash cycle or in 3 consecutive
    cycles on the latest software version). Control blinks the Clean
    LED 7 times repeatedly and disables the Start/Resume key until
    cleared.
    Running Diagnostics clears the control and allows it
    to operate again. The water heating condition
    must be corrected or the control will stop
    running again. See potential causes below.
    Check If…
    Heater circuit problem:
    ♦ Open heater.
    ♦ Wire disconnected, open connection or component
    in heater circuit.
    ♦ Faulty heater drive circuit on control.
    Then…
    1. Check operation of heater in Diagnostics cycle.
    2. Unplug dishwasher or disconnect power.
    3. Check resistance of heater and all components
    and connections in the water heating circuit or heat
    dry circuit.
    Door switch not making contact consistently:
    ♦ Misaligned door latch assembly (which can be
    aggravated by high door closure force keeping
    strike plate from fully seating).
    ♦ Faulty door switch (high resistance).
    ♦ Loose or missing installation anchor screws,
    causing tank to shift in cut-out.
    NOTE: Neutral switch on plastic tub models is only in series with
    the heater; other loads are not affected.
    1. Unplug dishwasher or disconnect power.
    2. Measure resistance of door switch contacts while
    checking mechanical operation of latch assembly.
    Confirm switches not loose from assembly. Check
    strike plate and door closure.
    Wash pump not pumping water past the heater efficiently.
    • Foreign object in pump
    • Excessive foaming
    • Clogged pump screen or broken chopper screen
    • Loose electrical connection in motor circuit
    See Tech Sheet “WASH PUMP WILL NOT PUMP”.
    Lack of water to heat. (Unit not filling properly)
    • Insufficient water supply pressure
    • Fill valve screen blocked or valve not opening fully
    • Loose electrical connection on Fill Valve.
    • Float switch obstructed or functioning abnormally
    See Tech Sheet “WILL NOT FILL OR LOW
    WATER”.
    Diagnostic Key Dance:
    Heat Dry - Normal - Heat Dry - Normal or
    High Temp - Air Dry - High Temp - Air Dry
    HOPE THIS HELP
    Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
    What tonnage are these units and is it a variable speed.
    The heat pump model number shows that it is a two and a half ton unit. I am sorry but I am not familiar with the air handler model number.
    May 07, 2009 | Heating & Cooling
    Smell of burning rubber
    alright so you have a heat pump with back up electric resistance heat. We need to determine if your odor occurs when the heat pump is operating, when the electric resistance heat is operating or both to isolate the possibilities since the issue is intermittent. Thermostat should have an emergency heat position, this will shut off the heat pump and operate the electric resistance heat only. If the smell/odor occurs then we have reduced the possible causes. let me know, happy hunting.
    Jan 13, 2009 | Heating & Cooling
    Working with 220 v
    If you are looking for a "window" type of unit yes there are some 220 volt units on the market. Most are large like 18,000 btu or larger. Check Lowes, Home Depot or larger appliance retailers for availability. Also know when buying if you need a heat strip, or heat pump if indeed you want heat.
    Nov 15, 2007 | Kenmore 75085 Air Conditioner
    Heating & Cooling Logo
    57 people viewed this question
    Top Kenmore Heating & Cooling Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    1STHVACMAN
    Bill Long
    Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
