Question about Garden
I changed the oil and white smoke poured out of the exhaust. Also there was oil spewing all over.
    Novelist:
  • 111 Answers
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Posted on Apr 05, 2011
White smoke pouring from exhaust
Hi, Anonymous for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
White Smoke out of Exhaust
White smoke coming out of the exhaust
DOWNLOAD Ducati 620
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 10, 2014 | Ducati Motorcycles
White smoke from exhaust when accelerating
White smoke means water on exhaust or gasket broken; check coolant levels ok. or re adjuts gasket.
Jul 17, 2012 | 1996 Nissan Sentra
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Radiator fluid starting coming out of my 97 jeep cherokee after driving home from work. The spill seemed to be coming from the middle of the engine compartment, and when I popped the hood, the fluid was...
I would follow the big rad hose at the top to the thermostat and see if the water is comming from there you might also want to check you oil for water/coolant, white pillows of smoke comming out of the exhaust pipe as well the smell of exhaust comming from rad ( those are some signs of a blowen head gasket )
Good Luck!
Sep 12, 2011 | 1997 Jeep Grand Cherokee
Ive got a motorcycle that was wrecked and know it has white smoke from the pipes
Most people consider white smoke to be oil burning in the engine. But that is not always the case. If the carburetors are pouring too much fuel into the motor that can cause white smoke to pour out of the motor. If oil or antifreeze got into the exhaust system , that could take a few miles to burn out causing white smoke. Lets assume the bike was laying on it's side for a few hours. Did you check your air filter and air box to see if they were full of oil. An overlooked air filter clogged with oil may be all that is causing this issue.
Aug 30, 2010 | kawasaki ZX-6R Motorcycles
White smoke from exaust
When white smoke is spewing from your exhaust, it is usually an indication that something is burning. The typical culprit is a burning fluid from the vehicle, but other causes are possible.
Oil, transmission fluid and antifreeze are the three fluids most likely to be the cause of white smoke coming from your exhaust. Ruptured seals, leaky bolts and blown gaskets can expose oil to hot spots, making it burn. Pinholes or loose lines can cause antifreeze to spray on the engine, while transmission fluid can be sucked into the engine and burn
Here is a form of solution or prevention which can help you out;
Keep your fluids at the appropriate level and change them at the recommended intervals to reduce leaks and maintenance issues. Use the proper types of fluids as well. The wrong transmission fluid can cause your gears to stick and wear down, while the wrong oil can reduce lubrication on the engine and cause internal damage. Improper mixture or wrong type of antifreeze can cause overheating.
Good luck.
Aug 03, 2010 | 1990 Nissan Maxima
My 99, a3 seems to be burning oil at the rate of a litre every 2 months and theres a bit of white smoke coming from the exhaust
2 things here, using oil & white smoke,
1. i would use a product made by seaform called motor tune-up, you can get at napa,autozone or kragen, pour contents in oil and drive normal, this product is real good been using over ten years it will clean all the carbon around the rings & pistons and also clean lifters,sludge in motor, run in for about 3 weeks then change oil stuff costs about $ 9.00
2. White smoke out exhaust is either automatic transmission fluid from transmission or slight head gasket problem
Feb 06, 2010 | Audi A3 Cars & Trucks
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Constant white smoke while running
White smoke is oil burn off. First off, check the oil level (sounds dumb, I know) and make sure the oil is not overfilled. Overfilling would be the easiest solution. If there is oil burning onto the spark plug but the oil is not overfilled, I would think rings... possibly scarring in the cylinder. Something allowing the oil to seep past the piston into the head. If the cylinder is scarred, there are .020 oversized pistons and rings available for the engines, rebore the cylinder and place those in.
May 16, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
