Question about Fisher Price Step and Play Piano
Step and play keys light up but there is no sound
HOW TO RESET WITHOUT TOUCH SCREEN
Using Hardware Keys Step 1Press and hold the "Power" key to turn off the Xperia Play.
Step 2Remove the back cover, and then take the battery out of the phone. Leave the battery out of the phone for a few minutes, and then replace it and the cover.
Step 3Press and hold the "Left" and "Right" directional keys under the screen.
Step 4Press the "Power" key while holding the "Left" and "Right" directional keys. The Factory Data Reset menu displays.
Step 5Use the directional keys to highlight the "Factory Data Reset" option, and then press the "Power" key to select the option.
Step 6Follow the instructions to complete the data wipe. The device powers down, and then boots back up. When the Xperia Play turns back on, factory default settings and software are restored.
Sep 24, 2014 | Sony Xperia Play R800x
Tip
Programming remote control
DIRECT CODE ENTRY
Step 1:Press and hold the device key (TV, VCR, SAT, etc) you wish to program. The illuminated ON/OFF key(*) turns on and remains on. If you release the device key at any time during theDirect Code Entryprocedure, the illuminated ON/OFF key blinks 4 times, and the process is exited.
Step 2:While holding down the device key, use the number keys (0-9) on the keypad to enter your equipment's code. While you are pressing the numbers, the illuminated ON/OFF key turns off.
Step 3:After the 4th number is entered, the illuminated ON/OFF key turns on. At this time, release the device key. If the illuminated ON/OFF key turns off, you have entered a valid code and have followed the correct procedure. If you enter a code that is not in the Code Lists or you do not follow all of the correct steps for Direct Code Entry, the illuminated ON/OFF key blinks 4 times when the component key is released - an indication that a programming error has occurred. In that case, repeat the process from Step 1 and try the next code in the list.
Step 4:To confirm that remote is programmed with the correct code for maximum functionality, test it. If some of the features of your equipment do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions as different codes can provide different levels of functionality.
* some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.
AUTO CODE ENTRY
If your component's brand is not listed in the code tables, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Auto Code Search method below. The remote will cycle through all of the codes, in the event that your code is listed under another brand. TheAuto Code Searchmethod may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand appears in the CODE LIST You should try first theDirect Code Entrymethod described above.
Step 1:Manually turn on the device you want the remote to control (TV, VCR, DVD, cable box, etc.).
Step 2:Press and hold the device button (TV, VCR, DVD, etc.) you wish to program. The illuminated ON/OFF key turns on and remains on.
Step 3:While holding the component button down, press and hold the ON/OFF key. The illuminated ON/OFF key turns off.
Step 4:After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 5:Release both keys. The illuminated ON/OFF key remains on.
Step 6:Press and release the PLAY button, then wait 5 seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every 5 seconds until your component turns off. Each time you press the PLAY key, the illuminated ON/OFF key blinks and a block of ten codes are sent to your component. This process continues until all of the codes have been searched. If your device has not turned off after all codes have been searched, the illuminated ON/OFF key blinks 4 times and turns off. The Auto Code Search Entry method is exited.
Step 7:When your equipment turns off, you know'll that the correct code is in the last block of 10 codes sent. Press and release the REVERSE key, Wait 2 seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE button every 2 seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON/OFF key blinks.
Note:If you accidentally press the REVERSE button after your device responds, press and release the FORWARD key. Wait 2 seconds to see if your component turns off again.
Step 8:Once your component turns on, you have found the correct code. You must save the new code by pressing and releasing the STOP key. The illuminated ON/OFF key turns off.
Important:You must press the STOP key to save the code or the correct code will not be stored!
MANUAL CODE SEARCH
Step 1:Manually turn on the component you want the remote to control and keep the remote pointed at it.
Step 2:Press and hold the component key (TV, VCR, DVD, etc.) you wish to program. The LED indicator light turns on and remains on.
Step 3:While holding the component key down, press and hold the ON/OFF key. The LED indicator light turns off.
Step 4:After holding down both keys for 3 seconds, the LED indicator light turns back on.
Step 5:Release both keys. The LED indicator light remains on.
Step 6:Press and release the ON/OFF key repeatedly until your component turns off. Each time you press the ON/OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
Because there are so many codes, you may have to press the ON/OFF key many times - possibly up to 200 times.
Step 7:Once you have found the correct code, you must save the new code by pressing and releasing the STOP key.
CODE RETRIEVAL
If you used one of the Code Search methods above to program your remote you may want to record the codes for future reference. Retrieving the actual code and writing it down will save you time if you ever need to program the remote again (when you change the batteries for example). If the codes are recorded, you can use the Direct Entry method to reprogram your remote to control your device, which is quick and easy.
Step 1:Press and hold the component key (TV, DVD, etc.) whose code you wish to retrieve. The illuminated ON/OFF key turns on.
Step 2:While holding the device key down, press and hold the INFO key. The illuminated ON/OFF key will turn off.
Step 3:After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 4:Release both keys. The illuminated ON/OFF key remains lit.
Step 5:Starting with the number 1 key, press and release each number key on the keypad in the following order: 1 to 9, then 0. The number that causes the illuminated ON/OFF key to blink is the first number of the code.
Note:
TV codes begin with the number 1
VCR codes begin with the number 2
DVD codes begin with the number 3
Satellite receivers and cable boxes, codes begin with the number 5.
Step 6:Repeat step 5 until you have retrieved all 4 numbers in the code.
Step 7:After the fourth number is retrieved, the illuminated ON/OFF key blinks briefly, then turns off.
Note:To exit theCode RetrievalMode, press and release the "GO BACK" button at any time.
For codes check the following link
Electronics Equipment Repair Center
on Jan 26, 2015 | RCA Televison & Video
I want cd key for prince of persia the forgotten sands to play this game please
oh my...does sound like a few bucks on a new copy would solve your problem
Jan 15, 2013 | Ubi Soft Prince of Persia: The Forgotten...
I have this message apprear on my laptop when i try and play sound "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device...
try playing the sound file with other media players, if still not playing reinstall ur audio driver either by dowloading the driver from internet or by installing it from ur driver cd.
if ur audio device driver is integrated or plug n play device then,
step 1:open control panel
step 2:open 'sound speech and audio devices'
step 3: in the property menu of audio devices select drivers from the tab
step 4:select uninstall driver.
step 5: restart ur computer and the audio device will be reinstalled.
if it is the problem with ur windows media player, then step 1:select option/preferences from the menu.
step 2:select devices from the tab.
step 3:test all the devices by selecting each one at a time to play ur sound file.
Jun 19, 2011 | Acer Computers & Internet
Fisher Price Step & Play Piano lights up but no sound.
I assume
No sound when baby steps on the keys (with high volume setting)
You have used alkaline batteries
You have tried replacing your betteries
Tried sliding the power and volume switch off and then back on
If you answer yes for all above then it is time to call Fisher price and ask for replacements.
May 01, 2011 | Fisher Price Step and Play Piano
My console dont play when i turn on red light flash and turn off and dont play
Sounds like Yellow Light Of Death. When it shuts off before the red light starts blinking is their a yellow light that blinks for less than a 1/2 a second? If not let me know and we can do a chat to figure out the problem. If it does then here is a link for my step-by-step instructions on how to fix it.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
I have no sound coming from my pc when i play songs and films
Hai,
I request you to provide complete detailed infomation on what sound card do you have and have you installed the drivers for the sound card and the operating system, however I will provide you few answers to your question.
Step 1
Press and hold windows key on the key and press R to open run box, in the run box type dxdiag and click on sound tab to check whether the sound drivers installed or not.
Step 2
Check the mute settings on the computer at the right hand corner you will see a speaker icon click on the icon to check mute settings.
step 3
I am providing you a weblink which has graphical representation of sound problems.
http://www.5starsupport.com/faq/sound.htm
please refer this weblink and click on the exact query and perform accordingly.
This should help you fix the sound issue.
Bye, take care.
Feb 02, 2010 | Computers & Internet
I have a J JVC RX-558V. The mute light is always on so it does not play sound. I can't find the key sequence on the front of the unit to disable Mute?
Apr 19, 2009 | JVC RX-558V
Sound Problem with MAC OS X 10.4.11
This sounds obvious, but the system volume could be down. Go to the System Preferences, and select "Sound". Make sure the output voumne is turned up, and the mute is not on.
If that doesn't work you could try "zapping the pram".
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound again. Continue this until you hear the startup sound four times.
  6. Release the keys.
Apr 03, 2009 | Apple Mac OS X 10.4
Z310i no sound plays for ringtones
step 1.take your mobile phone in your right hand
step 2.switchoff your mobile phone.
step 3.take a bucket full of water.
step 4.drop your mobile in the water and keep it for 5 mins.
step 5.takeoff your mobile from water.
step 6.clean it with your pant.
step 7.just switch on your mobile.
step 8.you will find a great change in your mobile
Jun 01, 2008 | Sony Ericsson Z310i Cellular Phone
Fisher Price Step and Play Piano Logo
Top Fisher Price Baby Care Experts
Tom Chichester
masud
masud
Are you a Fisher Price Baby Care Expert? Answer questions, earn points and help others
