Question about Refrigerators
I have a amana afi2538aeb4 fridge,which needs the water filter changed,please explain in detail this process.thank you..
HVACRH20
  • 237 Answers
SOURCE: Water Filter
Look up to the upper right corner of the frige section and you will see a long white tube with a small latch on the end. Looks smaller than a Pringles can in diameter. Pop the latch down and the cover will lower. Hold the back as much you can and twist the filter about 1/4 turn counter clockwise and it should pop out. Once you install the new filter run a couple of "KoolAid" sized pitchers of water through the door to get all the air out of the line.
Posted on Nov 10, 2006
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
SOURCE: Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
http://www.partselect.com/water-filter+reset-change-filter-light+repair.htm
Posted on Aug 08, 2008
  • 219 Answers
SOURCE: amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Posted on Mar 19, 2009
Maytag317
  • 1136 Answers
SOURCE: how can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Posted on Jul 17, 2009
I have an Amana side by side refrigerator model ASD2522WRB06. I replaced the filter that is located in the grill at the bottom of the fridge. Now water does not flow at all.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system.
http://appliance911seabreeze.com/
Nov 14, 2015 | Amana Refrigerators
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
My Frigidaire side-by-side leaks inside, from water filter
the gasket that holds the water pressure in between the water inlet line and filter is not in proper position, or your filter sir is nt properly inserted into the slot,the cycle starts when the water comes in,pressure will build up and it will start t pass in between the gap, as the pressure goes down, dripping will stop, then cycle start again, check the connector sirandhose connected into the filter
Mar 18, 2010 | Amana ACD2232HR Side by Side Refrigerator
Where is the filter on a Amana SQD23VW
CLICK HERE for all the blowout diagrams of your fridge.
CLICK HERE for your Owner's Manual in PDF format.
CLICK HERE for your Installation Instructions.
The water filter is found in rear right corner of refrigerator section. Twist cartridge counterclockwise 1/4 turn and pull down to remove.
Some fridge model levels did not have a filter and you will find a bypass cartridge there instead.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana fridge water dispenser real slow
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
Water and Ice in Door Tastes Awful!!!
If your water tastes ok without the fridge then you'll need to replace or clean the piping inside the fridge.
If your water has the same smell and taste without the fridge then you'll need a better grade filter on the water going into the fridge.
If it's in your fridge piping try going to a plumbing supply and ask them for a cleaner to run through the fridge!
jack
Mar 08, 2009 | Amana SXD524VW Side by Side Refrigerator
Change the water filter
Most are ok to pull as there is a shutoff in combination with feed lines... If in doubt and the water shutoff is convienient to get to turn it off. Otherwise just pull the filter...especially if it simply snaps into place as it should take care of turning off the water as the filter comes out....
Feb 15, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
