Question about Samsung Televison & Video
Lls.comI need to access Samsung lnr26r5 hdx I need to access to set the tv to HDMI I don not have the remote. Is there a direct entry
  • larry914 Apr 05, 2011
    The menu button is not active anyway tio activate it. All I want to do is plug computer from HDMI to HDMI in on TV but I can not change TV to HDMI input. There should be a way to activate the buttons
    President:
  • 1,140 Answers
Hello Larry,
You should be able to access the HDMI input using the buttons on the front of the TV. Press the SOURCE button to open the input list, then use the CH+/- buttons to highlight HDMI and then either press SOURCE or VOL+ to select the HDMI input.
The buttons may be in a different position on your model, but all of the buttons shown above will be on your TV and the method for selecting the HDMI input will be as described above. This is not a common model and it's quite difficult to get precise information for this one.
If you need further assistance, you can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric.
Posted on Apr 03, 2011
Directions for activating netflix on a samsung 4 4000 led tv
I had the same problem the bottom line is call Netflix and they can walk you through it
Netflix Customer Phone Number Shortest Wait Best Support
888-638-3549
Feb 06, 2015 | Netflix
HOW DO I CHANGE MY TV VIDEO SOURCE TO THE HDMI1 VIDEO SOURCE USING MY REMOTE CONTROL
On my Samsung TV remote, there is a button that allowed me to access choosing the option of either HDMI, or antenna. As soon as I chose the right setting the picture was displayed. You may have to click around through the options until you find it.
Sep 18, 2014 | Dynex Televison & Video
Why won't my Kindle fire play on LG 32 inch flat screen TV
If its the Kindle Fire HD, you will need to use a micro hdmi cable to connect the kindle to your tv via the hdmi port.
If its a Kindle Fire HDX, there is not a port to use as it uses Mira Cast. Your tv may or may not have this feature. If it does, you can go to display in your Kindle HDX settings, and use display mirroring. If your tv doesnt have this feature you will need an adapter call Push2Tv.
Does this help or are you trying this with a Kindle Fire?
Apr 06, 2014 | Televison & Video
How do set the resolution on a samsung 50" plasma (ps50q7hx)
make sure that the tv is in "HDMI" mode. If there are multiple HDMI ports on your tv then check to see which one it is. You should see HDMI 1, HDMI 2, etc. Then when you are sure what port it is in on either your tv directly or using the remote press the input button until the desired input is selected. So for example, if you have it in HDMI port one, press the INPUT button on either your tv or remote and cycle up or down until you select HDMI 1 and that should do it! sorry if it doesn't!
Dec 13, 2012 | Samsung Televison & Video
I bought a used samsung t.v. and the remote don't work. its got new batteries but don't work it might be a samsung universal remote do i need to but my t.v. code in it. how do i do it and what is...
Hello
Three digit universal remote codes to check with Samsung tV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 26, 2011 | Samsung TV Remote Control
I need instructions on how to set my RCR312W for a Samsung TV, just the TV
Hello
There are four digit and five digit codes that can be synchronised with Samsung TV to RCR312W.
1004, 1005, 1006, 1012, 1013, 1015, 1017, 1019
Five digit codes are:
10812, 10054, 10060, 10702, 10178
Instructions:-
Direct Code Entry
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand.
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Jun 01, 2011 | RCA RCR312W Remote Control
How do I program old Samsung to control power and volume on new Samsung TV?
Hello
There are two ways to set a remote with a TV. They are direct Code Entry and Code Search. i'll give here both the proceedings. OK.
Direct Code Entry
Mar 19, 2011 | Samsung TV Remote Control
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
Can not connect my MEDION 8828 MD computor via a HDMI cable to my SAMSUNG ps42q97 hdx 42
use a vga connector. this tv doesn't support pc mode on hdmi. don't forget the 3.5mm stereo jack out fron your sound card to the 3.5mm input(next to vga on tv). you will get 1024x768 res.
Dec 23, 2007 | Computers & Internet
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
