Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
I'D LIKE KNOW THE CARACTERISTIC ABOUT THIS COMPRESSOR. MATSUSHITA DB91C14RAW5 22O VOLTS 50 HZ.
Can I use American appliances in Europe?
yes with a voltage converter and plug changer (usually all in one device) ive been to london and paris several times for cooking school and took my own blender F/P (it's got special features i like) i had to bring the converter with me both trips , As i never saw one there for me to use ,not once .
great brittan has 220 volts 50 Hz
france has 220 volts 50
belgum has 125 volts 50 hz
and of course all over N/S americia's is 120 volts 60 hz
except Bc canada they have 220 volts 50 hz
May 18, 2014 | Waring MX1200XTX Xtreme Bar Drink Blender...
My camper fridge , Engel SRBT-565D Does not run on 12V ?
The compressor is on the way out and exceeds the current capacity of the 12v inverter circuit. The compressor runs on 32V AC @50 Hz and the inverter circuit is not able to produce sufficient current when the compressor becomes worn. It still runs on 240V circuit as this is a straight step down transformer from 240 volts and is not current limited..
May 20, 2012 | Freezers
How can i change the power from 110 volt to 127 volt, jamaica is 110
Voltage is not the problem. The issue is a 60 hz machine in a 50 hz country. The fix is to buy a Jamaican washing machine.
Mar 03, 2012 | Daewoo DW500M Top Load Washer
I'd lke know, the HP of this compressor MATSUSHITA DB91C14RAW5 thanx
According to the information you have given it is a one quarter horsepower compressor
designed for R134 refrigerant. It runs on 115 volts.
Apr 03, 2011 | Matsushita DD73C14GAU6 1/4 HP R134...
I have just come across a Matsushita Electric National Food Processor. Made in Japan Model MK-5070N\r\nSerial # 107529 230 Volts 350 Watts 50 Hz I am just wondering where I can possible source a manual...
You will need to post a query to the official site of Matsushita for help:
www.panasonic-electric-works.net
check on also
www.manualsonline.com/ex/device/headline/d/???food_???processor/type/???manual_???request
Sep 30, 2010 | Food Processors
Hi i am a refrigeration mechanic and i need a compressor for a chest freezer, here are all the reference numbers on the compressor, can you tell me the specs so i can get a match. SMH 2598133 Model no:...
i think any 1/3 hp 134a compressor will work you just have to make sure the fitting are in the right place,i got mine on ebay for $50 or you can check sears.com(parts) or repair clinic .com,let me know how you do-mike
Oct 28, 2008 | Refrigerators
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
149 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
