Question about Wharfedale Televison & Video
Region setting - Wharfedale Televison & Video
  • 376 Answers
What make and model?
Posted on Aug 05, 2008
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Changing the DVD Region code
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Setting the player to region free
Apologies everyone.......
The instructions for the DVD-P181 are actually correct as described in other posts but can be a bit confusing. Please allow me to clarify using my example;
With your DVD-P181 switched on, follow these instructions using your Remote Control;
1/ Press the <DVD> button
2/ Press <0><0><0><0><0> (this is 0, 5 times)
3/ Press <repeat> (careful not to press the <repeat A-B> button)
4/ Press <7><6><8><8><4> (ONLY if your player is currently region 4 - refer to the table below for other pre-set regions)
5/ The Region window should now appear on screen saying that your current region is Region 4 and asking what region you want to change it to.
6/ Press <0> for the new Region (0 is region-free)
7/ Press <Open/Close> button once (to open the tray)
8/ Press <Open/Close> button again (to close the tray
9/ Press <Power> button to turn the player off
Now, when you turn the player back on, you should be able to play DVD's from any region. Good luck everyone.
_______________________________________________
This table refers to Step 4. You need to choose the Region code which your machine is currently set to, to unlock the Region Menu which allows you to set the device to another region.
In my example, the DVD player was purchased in Australia is by default set to Region 4. The 5 digit number I needed was 76884.
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Dec 28, 2008 | Samsung DVD-M105 DVD Player
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
Unlock sony DVP-FX720
The problem may be you are trying to play DVDs from a specific region (Europe) and the player is set for another region. Region code errors will show up as "no Play" or 'region" Check the manual to see how to set the player to Region 0. A region machine will play any DVD. Sometimes the setting is on the menu - usually in the set-up screen under "region." I have re-set all my Phillips players to become Region Free through the menu.
Aug 22, 2008 | Yamaha DV-S5450 DVD Player
since the changes remaining is set to 0, sorry to say that you cna no longer change this to a different regional setting, unless you reinstall the OS,
chances are you have selected the region previously, or somebody else.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
or you can install one of this program:
The region can only be changed five times, before its set permanently.
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
hope this helps dont forget to mark my solution pls
Aug 07, 2008 | Microsoft Windows XP Professional With...
Unlocking zone for samsung dvd-p181
One of these 2 should work.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT (do not confuse this with the A-B button) then the following codes for the required region the player is already set to (region you bought the player in) :
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 0 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
<DVD> ; press DVD button
<0><0><0><0><0> ; enter 5 times 0
<repeat> ; press repeat button (careful, not <repeat A-B>)
<5 digit code> ; see below, depends on region the player is currently set to
<0 for region free, 1-6 for other region> ; select new region
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Note: reset player by powering down and simultaneously pressing <power> + <play> until display shows 'reset'.
Aug 04, 2008 | Televison & Video
Brough DVD's from america. Wrong region for Australia. I have a Samsung DVD P181/XSA player. How can I play my dvd's. Is there a way to break the region code on my DVD player?? Thanks Sylvia ...
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 .
OR
<open> ; open tray
<open> ; close tray
Now power off/on
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Jul 30, 2008 | Televison & Video
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
Jul 05, 2008 | Samsung DVD-P244 DVD Player
Trying to change region to 2 but it has locked me out is there a code i need
you can only change ur region codes a few times then ur drive becomes locked to the last reset.then youll need to reflash ur drive with firmware.theres a program u can get(free)called any dvd which gets around region codes.
I personally would reflash firmware.this sets drive to "0" which is all regions.
simple precedure.locate firmware,download it,write it to a cd,insert cd which then reflashes auto.remove cd.
Mar 26, 2008 | HP Pavilion dv4000 Notebook
Televison & Video Logo
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
