Question about eMachines ET183103 (PTNB602002) PC Desktop
Windows error at startup.what can i do to fix?
  • 2,229 Answers
The best way is to put a Windows CD/DVD in and boot from that.
It depends on what operating system you have to go from there.
If you have Windows XP, follow this:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
If you have Windows Vista or 7, you should be asked if you wish to repair the Windows O/S. Say "yes"
Posted on Apr 03, 2011
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
Apr 01, 2015 | Dell Inspiron N5030
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Error code 0x800704B3 how to fix?
You have not mentioned what Operating System you are using so I assume it is Windows 7.
You will face this error if your RAM is very low. The main source of performance decreases are startup clutter, registry errors, RAM decline, fragmented files, unnecessary or redundant program installations.
In order to fix your errors and PC speed, it is recommended that your download the 'Error Code 0X800704b3 In Windows Repair Tool' from the link below. Ultimately you may also add more RAM and increase your storage space.
How To Fix Error Code 0X800704b3 In Windows Errors Windows XP Vista...
Nov 11, 2014 | Computers & Internet
My acer aspire 5732 at startup shuts down then starts up shuts down
Such problems occurs due windows internal errors. I would suggest to fix windows errors, also scan PC for registry errors. WebRepOverall ratingThis site has no rating(not enough votes)
For an instant fix use system optimizer PCFresher
Dec 07, 2012 | Acer Aspire 5735 Notebook
Inspiron 5110 slow startup
Assuming you are using windows 7...in the run window type msconfig
After the window opens up, click on the startup tab and uncheck anything that you don't want to start automatically when windows starts. Becareful in here though, you can disable your windows if you aren't careful. You may also want to run your antivirus to make sure that nothing is hogging your resources at start.
Nov 23, 2012 | Computers & Internet
Freezes after few minutes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Sep 11, 2010 | IBM ThinkPad T40 2373 Notebook
Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Sep 04, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Vaio sat survey not working
Jul 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
Im using windows xp sp2 and my startup is incredibly slow. im using alienware themes and alienware dock starts on startup.other than that ive changed the startup tune to something i converted on my own....
Sounds like you are running out of ram for the program. Try upgrading to some more ram in your system. Windows xp recommends minimum 512k of memory to run.
Dec 29, 2009 | Microsoft Windows XP Professional SP2
eMachines ET183103 (PTNB602002) PC Desktop Logo
46 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
