Question about GE Washing Machines
I have a model wwwa8800 that has no water pressure going into it and takes a couple of hours to wash a load of wash.
  • 4,340 Answers
Check for restricted screens in the inlet of the HOSES and the inlet valves. Pariculate matter plugs them...
Posted on Apr 03, 2011
Why does it take two hours to wash a load of clothes
We have a new machine and a couple of the settings take about that length of time. We have a setting that does a wash load in around 30 minutes and tend to use that. It is a lower temperature and a slightly slower spin speed (1100 instead of 1300).
I believe it is because modern machines only have a cold water fill and no hot so the water has to heat up to whatever the setting is.
Try a lower temperature and spin speed, or if your machine has an "eco" setting, give that a go.
Sep 25, 2015 | Washing Machines
I have Model AWZ410 Washing machine, the washing cycle now takes up to 6 Hours!
i have experienced a machine doing this it was caused by the outlet hose pipe not alined it was syphoning water intermittently so check the hose outlet. 2nd
the wash heater may be open circuit causing the wash cycle to stop, the timer is then manually turned to continue washing .3rd check the pressure switch hose for blockage by taking it off the switch and blowing down to clear any blockage.
Feb 17, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
I used aml 85 ariston washing machine but it takes time to wash it takes 2 and a half hour to finished.how can i make quick washed for this.i want like 1 hour wash only
Select a quick wash cycle which will take in less time to load water , rinse and spin, Also choose with a smaller load. check the INLET water pressure to be good, check the drain to be effective, if not clean both the valves..
Jan 23, 2013 | Washing Machines
Dirty water......
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 05, 2010 | Frigidaire GLWS1339AS Top-Load Washer
Water leaking from base
There should be an access cover at the bottom of the machine, Take it off and check your pump, the hose going from the tub to the pump, and the drain hose.
Nov 07, 2009 | Electrolux EW1000i Front Load Washer
How can I reduce the time needed for a wash ? It takes 2 hours is there any way to make it less ?
Most machines have a soil level selection (light / normal / heavy) and if you select light soil level the wash time is reduced. Also, some machines have a " Quick Cycle " which cuts a lot of time off, which should only be used with lightly soiled clothing. Additionally, make sure you have adequate water pressure, and that the inlet screens are clear so that the cycle is not delayed essesivly due to slow water fill. Regardless of all these, the higher spin speeds of a front loading machine (those have the longest wash times, due to the low water use and the tumbling wash action used vs an agitator in a top load machine) will result in reduced dryer run time, thus helping to reduce the overall time a load takes to wash and dry. (although still longer than most top loading sets) Generally, the energy savings and larger load sizes will outweigh the extra time the machines take.
Sep 16, 2009 | Washing Machines
TAKES HOURS TO GO THROUGH THE CYCLES
Please check that the inlet filter for the water is not blocked, reduced inlet of water will extend the wash and rinse times by a considerable time.
Run the machine with the water turned off at the fawcet that will take the pressure out of the hose
Switch off the machine
Unscrew the connector at the back of the machine which holds the supply pipe in
Look in the hole which is revealed is ther a load of bits of grit and gunk in there , if there is pull out the filter and give it a wash under a tap.
Jun 05, 2009 | GE WSXH208A Front Load Washer
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Snap-on spigot coupling won't stay connected
Sounds like too much water pressure or, more likely, the coupler has worn down. You can get a replacement at most hrdware stores.
Nov 03, 2006 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
13 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
