Question about NetGear WNR2000 Wireless Router
I have internet access when I plug in the ethernet cable from the modem, but when I try to access the internet via the router it says 'connected but no internet access'. What is the problem?
  • Tony Apr 03, 2011
    can you check to see if your router is getting a WAN IP?
  • 60 Answers
I know it is very frustrating if these things do not work. I am sure that the router is not setup properly that is why it is not working. It says connected because you have a good connection from pc to the router. But the connection from your Netgear router to the modem is not working. There is a possible IP conflict between your modem and router. I suggest changing the IP address of your netgear router to 10.10.10.1 . To do this click the link below:
ftp://downloads.netgear.com/files/WNR2000_UM_24FEB09.pdf
Note: This is the manual for your router. Go to LAN TCP/IP Setup Parameters to change the router's IP address.
Posted on Apr 05, 2011
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Ethernet Card
Do a ipconfig at the command prompt and see if you are being assigned a ip from the modem. If not try rebooting the modem with the ethernet connected to modem and computer. then do ipconfig again to see if not getting internet ip, your card or modem eternet is bad. put in a new one and try again.
Jun 01, 2008 | HP PAVILION A6230N DESKTOP PC
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Wireless configuration
What you will need: Wireless router and a wireless adapter connected to your PC. This is assuming you have a broadband internet connection. Install the wireless router by taking the ethernet cable out of the back of your computer and placing it in the WAN or internet port in the back of your router. Install the wireless adapter inside your PC. Unplug your modem for a minute or so. Then plug in your modem and your router, then turn on your PC. If you are running XP, it should see a list of wireless access points you can access. Select the one for your router (should be the strongest) and hit connect. This will connect you to the wireless router and the internet. Note this solution assumes the following: You have a high speed internet connection, your ISP's modem is connected to your computer via an ethernet cable, and you are running windows XP.
May 19, 2007 | RCA DCW615R Wireless/Cable Modem
NetGear WNR2000 Wireless Router Logo
117 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
