Question about Samsung Syncmaster 940BW LCD Monitor
Whitewashed screen At my new job I'm using a syncmaster 940BW, but the screen appears "white washed" or washed out. Icons and photographs appear washed out. I've tried adjusting the levels using the buttons on the monitor, but that doesn't help. Any suggestions?
  • 1 more comment
  • Natalie3733 Sep 02, 2008
    I have the same problem. We tried changing every setting, reinstalling driver, software and such and nothing helps!! This was a gift someone gave to my daughter. After trying everything we just figured she was given a cheap monitor. But now, after reading all these reviews on line I have discovered that people are very pleased with this monitor. WE ARE NOT PLEASED WITH OURS!! All the colors seem faded....like the graphics have been washed with bleach!! Horrible to use and ******* the eyes. I am thinking of dumping this thing in the trash. Can anyone help?
  • craigd2599 Feb 20, 2009
    certain colors are washed out. Some colors still work fine. Also...at start up when it should be black it is a blue / green very very fine lines through the screen
  • steven7942 Apr 13, 2009
    I don't know where to begin on fixing this problem, can anyone help? It was working yesterday :(
Bring it to the service center for a check up
Posted on Sep 30, 2008
SOURCE:
My SyncMaster 940BW Samsung monitor does not respond to any Laptop/computer connection. The on/off blue botton is blinking. It worked well a while ago. ANy suggestions?
You can try to disconnect VGA cable to see will the notification "no VGA signal" appear on screen. If so the problem could be with PC graphics, else it is power board problem bad caps.Thanks
Sep 29, 2013 | Samsung Syncmaster 940BW LCD Monitor
I have a samsung syncmaster 940bw the other day while using it while surfing the web the screen went white and i cant seem to be get access to the menu on it
The screen went white can be due to failed T-CON board or failed power supply, I would inspect the power supply and the ribbon cable between the logic board and the LCD panel.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 28, 2010 | Samsung Syncmaster 940BW LCD Monitor
I have a Samsung SyncMaster 940BW. My young son played with the menu bottons and I cannot restore the screen to its original settings. How do I restore to factory settings?
catchymob, If, with monitor OFF, push and hold "menu" button, and then push the "on/off" button. Still not reset? Try visit to Samsung web site. Hope this helps. 12fixlouie
Let me know with reply or comment from you.
Aug 13, 2010 | Samsung Syncmaster 940BW LCD Monitor
Samgung pc monitor has a plain white screen when turned on. Also goes off after a short while and the blue power button blinks.
plain white screen means loose conecting the lvds cable to panel. reconect it.
if its goes off then check power board +5v or +14v filter capicitor.
Feb 17, 2010 | Samsung Syncmaster 940BW LCD Monitor
Can improper earthing results in white screen problem of the LCD monitor?
No, it sounds more likely to have lost power to the LCD controller.
Nov 30, 2009 | Samsung Syncmaster 940BW LCD Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I bought a new computer and it isn't recognizing my monitor (blank screen)
Most monitors use software that you load onto the new computer. Look for a disk or hook up the old PC to download it.
Jan 10, 2009 | Samsung Syncmaster 940BW LCD Monitor
940bw monitor
White screen is normally a defective panel.
Samir
Jun 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Open Questions:
See all Samsung Syncmaster 940BW LCD Monitor Questions
Samsung Syncmaster 940BW LCD Monitor Logo
634 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
