Question about Tomtom GO 910
Tomtom go 910
I switched on my tomtom go 910 but only shows green screen and then appears an X on the right side and doesn't give anymore information.
  • nobend Aug 30, 2008
    When is opened the box and took out contents I read instructions got as far entering my address the screen froze I could not turn it off I left it not knowing what to do Tried it later it had gone off. I swiched it on screen froze with a hand and a cross
    Novelist:
  • 158 Answers
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Posted on Sep 23, 2008
    Problem Solver:
  • 3 Answers
I switched on my tomtom 910 but only shows green screen and red x on right side and doesn't give anymore information
Posted on Oct 07, 2008
GPS Status screen on tomtom 910
On the normal screen tap the time info to get summary screen.
Then tap satellites (top right) and the GPS Status page appears
Apr 05, 2010 | Tomtom GO 910 GPS Receiver
Tomtom 730 doesn't switch on!
Hopefully all you need to do is a soft reset. To do this use a streightened paper clip and insert it into the small round hole marked reset on the bottom of your tt. Gently press the reset button in until you feel a click. Hold the reset button in for 20 seconds. Hope this does the job.
Jun 07, 2009 | Tomtom GO 910
What do you use to charge the tom tom 910 in the house
In the box you have a 'desktop' mount. Looks like the windscreen mount without the ******.
Also you will have got a mains power lead.
Plug the lead into the 'desktop mount' (Left hand side) of the stick up bit.
Plug in and put your 910 onto the mount. It will 'Click' into place
The green light will shine to show it's charging.
To release the unit from the mount PRESS in the button in the middle of the screen top rim and lift off.
Remember to turn of the power at the socket to stop wasting electricity
The usb part of the desktop mount goes into your pc so you can connect to TomTom home or just plain old 'back it up'
It is ok to have power switched on or off when connect to the pc, there is no need to unplug the jackplug.
Hope this helps
Feb 28, 2009 | Tomtom GO 910 GPS Receiver
Safety lock
Yes, I too have experienced a problem with locking up when I take my TomTom 910 out of the dock after being connected to my computer. I also took my TomTom back to shop and was shown how to do a Hard Re-set on it. Firstly, you have to locate the reset button (which I see you have. Why it is hidden away in such an awkward position I don't know. I carry a pin/paperclip around with me for this purpose!) Press the reset button once until the TomTom screen switches off. Then with the TomTom off press AND HOLD DOWN the On button on top of your TomTom. Keep holding as white computer script appears on the screen. Carry on holding down until the remainder of the script appears to almost fill up the screen with script info and then this stops. Then release the On button and the TomTom icon will appear. After 2 to 3 minutes the TomTom should switch to show the current location map and look for satellites. Locking on to satellites can then take up to 15 minutes by the way.
Hope this helps.
Good Luck!!!
neo
Feb 27, 2009 | Tomtom GO 910 GPS Receiver
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Mar 25, 2008 | Tomtom GO 910 GPS Receiver
Tomtom 910.
Mar 23, 2008 | Tomtom GO 910 GPS Receiver
TomTom 910 problem
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 21, 2008 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 Logo
215 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
