In this FixYa article, http://www.fixya.com/support/t1343025-frigidaire_ac_heater_window_unit_problem ... it addresses a lot of my problems that I am having with my unit. Toward the bottom the helper guru guy suggests to go find the wiring guide for my unit (info to be given blow) here: http://www.frigidaire.com/customersupport . I'm not the sharpest tack in the shed so I'm not having much luck finding it. I found this monstrosity, which to layperson like myself is just...OK - numbers...what the heck with numbers?? http://c.searspartsdirect.com/lis_png/PLDM/R0704064-00001.png OK, it's all the parts of my unit in the order the are fashioned together to make the thing in my window! got it! I still do not know where to look for the items he said to check. I would Love for my heater to work after the 3+ years I've had it now. (Sister bought it and promptly lost all manuals and receipts so it couldn't be used for warranty) Also, if you could,, I do not own but the most rudimentary of tools, is there any way you can tell which I will need to look inside and possibly do adjustments? One last mind blowing thing that I'm curious if you have ever heard of. It is not problem for me, it happened and i have learned to live with it, but, last Spring (always something wrong in Spring when it's 90F already in Florida and its the first couple fire-ups of the unit - I was trying to find out why my fan wasn't spinning - problems solved in my own way in the end so its OK) something electrical went amiss and it blew the breaker as it should to prevent bad thigs from happening. I reset the breaker, plugged it back in , hit the reset button and turned the unit on. It work fine, however, it has now decided it wants to read in Celsius instead of Fahrenheit !! There is no button, no switch or anything that I can find anywhere that is meant to change it...nor is there anything in the manual PDF I've DL'd about this even being a possibility of something that can be done. I've known since the beginning that my unit is a little bit "special" Dropped on his head when he was shipped too many times perhaps...but have you herd of this happening before and if so do you know why? I don't need to change it - I'm used to it at this point. broadened my horizons if you will, just a curiosity. Here is my make, model and serial: Frigidaire Model: FAZ08HR1A Serial: IK72006612 Thanks in advance, much Kudos!
sandrew
  • 2961 Answers
SOURCE: Acer Ferrari 4005 freezes and does not switch on again easily
When and if it's running, run 'dxdiag' to see if windows reports any sound and video conflicts. It could be the graphic card; as i think(correct me if i'm wrong) that this model has seperate dedicated graphics, other than being on board. I'm assuming all drivers are ok and none of the vga or dvi ports give you any video either. Although the graphics are independent, it's not like a desktop pc graphics agp card, they are; as far as i know integrated in the motherboard, so the board may be the but of your problem, in which case is a replacement worth it or is it within the warranty period.
Posted on Jan 02, 2007
  • 105 Answers
SOURCE: Window A/C needs cleaning - lost manual
Remove the front panel & see if the unit will slide out of it's sleeve. Usually it is the sleeve that is bolted in, & the unit itself will pull out from inside.
Posted on Jul 15, 2007
  • 18 Answers
SOURCE: maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Posted on Oct 14, 2007
  • 324 Answers
SOURCE: T41 screen help
I think that most of the information that I can provide is in that article. If you have specific additional questions, I can try to help. By the way, the T41 that I couldn't get running ended up needing a new mother board. Oh well...
Ron-
Posted on May 08, 2008
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
Frigidaire model# frs6lf7jso my compressor dosnt seem to be kicking on while the in side seems to be cool but not cold and the freezer is thawing. what should I look for as the problem this unit is only 3...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 25, 2011 | Frigidaire Refrigerators
I have 75 volts ac at the heater element
Checkout the tip for the electric dryer...you have a problem with something cutting out the current before the element...probably the high limit ...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire dishwasher does not seem to be "heating up". Have tried turning up the temp on water heater but it did not help.
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 15, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Frig, not cooling or freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 26, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidarie front loading washer will not kick into spin cycle
You haven't given a lot of information here, but I suspect that my recent article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning
may well help you
Oct 09, 2009 | Frigidaire Washing Machines
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
