Question about Raymarine C120w Widescreen Multifunction Display
Which cable on NMEA 0183 to conect to Navman radio VHF 7000 range
3 Suggested Answers
  • 64 Answers
SOURCE: NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Posted on Jun 14, 2010
  • 8 Answers
SOURCE: what is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Posted on Jan 25, 2012
Uniden um425 vhf to navman trackfish 6600 what coloured wires do I connect.
Hi Gil!
Easy peasy.
From your 6600, the data sends are the white wire NMEA (+) and the black wire (-). There are two black wires. Doesn't matter which one you use as they're interconnected anyway.
To your UM425, the green wire is NMEA in and the bare wire is ground.
So...
white from 6600 to green and
black from 6600 to bare.
Hope this helps you out.
-Steve
Jan 09, 2015 | Uniden Boating
When installing elite 5 XHDI what do I do with the data cable, the one with 5 wires?
I'd be very hesitant about just cutting off the data cable. Because it has NMEA 0183 capability, in the future if you plan to hook it up with a DSC VHF radio, an autopilot or the like, you'll wish you hadn't!
Hope this helps.
-Steve
Oct 15, 2014 | Boating
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Jun 11, 2014 | Lowrance Boating
How to hook a uniden vhf radio to a garmin 4208 for nmea operation?
Hi
I realize this question is old, but for the benefit of someone else who might have the same query, the NMEA 0183 outputs from the 4208 are the gray (+) and black (-) which go to the data in of your DSC VHF. The data OUT from your VHF connect to the white (+) and black (-) of the 4208.
If using NMEA 2000, using the second link below, start on page 10.
The installation instructions are about halfway down on the link page and can be accessed directly from the install link below if you prefer. -Steve
http://support.garmin.com/support/manuals/manuals.htm?partNo=010-00591-01&language=en&country=US
http://static.garmincdn.com/pumac/GPSMAP_4000-5000_Install_EN.pdf
Apr 28, 2014 | Uniden Boating
Colour codes of output data cable explorer 650
From the owners manual (page 78, link below) NMEA out (+) is the white wire and NMEA (-) or ground is the black wire.
-Steve
http://www.northstarnav.ca/upload/Northstar/Documents/EXPLORER_650.pdf
May 14, 2012 | Northstar POWER/DATA CABLE FOR EXPLORER...
I have a Philips GPS Dantronik Navigater MK9 an now a Northstar VHF Marine Radio Explorer 710. I want to connect both over NMEA to get the position form the GPS to the radio. There are 7 different...
I connected my ICom using the NMEA in. I had the leads reversed first time, moved them around and worked. This was a connection from Furono to iCom but should be much the same
Jun 01, 2010 | GPS
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
May 17, 2010 | Icom IC-M302 VHF Marine Radio
Does this unit have a distress signal that a Nema 0183 data cable can attach to
See below:
GPS RECEIVER LEAD
Connects to a GPS receiver for position indication.
• An NMEA0183 ver. 2.0 or 3.01 (sentence formatters RMC, GGA,
GNS, GLL) compatible GPS receiver is required. Ask your dealer
about suitable GPS receivers.
Color code:
Yellow: NMEA IN (+)
Green: NMEA IN ( )
Feb 19, 2010 | Icom M302 VHF Radio
Integrating AIS, Radar, Autohelm 7000 and flux gate compass.
ActiSense makes a programmable multiplexer that should do this for you. It is called an ActiSense NDC4 USB. Not sure is the Standard requires a separate compass signal, but if not, and the Standard can use a standard 38000 baud AIS data stream, the NDC4 will work for you. 847-746-0100
http://www.blueheronmarine.com/Actisense-NDC-4-USB-NMEA-0183-Multiplexer-with-USB-Port-6334
Jan 30, 2010 | Standard Horizon Cpv550 Gps Chartplotter...
Raymarine C120w Widescreen Multifunction Display Logo
70 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
