Question about General Electric WCVH6800J Front Load Washer
Washer will not stay balanced - General Electric WCVH6800J Front Load Washer
    Scholar:
  • 44 Answers
The washer balance is mostly controlled by two factors:
  1. Balance of the appliance cabinet (shell)
  2. Suspension of the tub inside the cabinet.
As far as the cabinet is concerned, balance, level, and plumb are determined by the adjustable feet. Installers usually come in with a level and test the level (side to side parallel to ground) and plumb (front to back perpendicular to groud). Many times they overlook the corner to corner balance. I think corner to corner is more important than being plumb or level. Try adjusting.
If that doesn't solve your problem, you may want to check the tub suspension. There are shock absorbers beneath the tub that push in opposite directions to keep the tub balanced in the cabinet. You can access them by removing the front access panel (diagram below -- remove 3 screws and pull out from the bottom to let it fall down)
You will see the shock absorbers in plain view. Wiggle the tub around to see if one is any weaker than the others. If so, replace it.
If you find this advice helpful, please rate me as I am trying to obtain the "Guru" status so I can offer premium support.
Thanks,
Chris
Posted on Jul 29, 2011
Washers will not stay on
the switch that activates when out of balance is the same switch as the lid switch and it is activated by a small lever
if the out of balance was really bad ,that lever can get on the wrong side of the lid switch and keep it as if the lid is open
Jul 14, 2015 | Washing Machines
How do I balance a Kenmore 70 series washing machine.
Wood laminate flooring is never a good idea in areas that can get wet often. But, that being said, there should be leveling feet on the washer which should allow you to get it stable on the floor, if that's what your problem is. If your problem is that the washer tends to walk around the room when in the spin cycle, well that is partially due to the fact that washers often vibrate when they spin, especially when spinning large, bulky objects like quilts and comforters, that the feet on the bottom of washer are smooth plastic, and that smooth plastic feet don't stay in one place to well on wood laminate floors.
Mar 04, 2015 | Kenmore Washing Machines
Out of balance on spin cycle (machine is level)
The balancing straps that hold the drum in balance could be broken or the springs could be wore out.
Jan 11, 2010 | Washing Machines
Washer stays out of balance
most likely a spring has come off the tub base. there are three short horizontal springs that surround the tub connecting it to the tripod base and one long spring in the very back that connects the base to the bottom back. check these out and reattach if off.
May 24, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My top load washer stays off balance.
one or 2 of the springs under the tub are worn out or broken loose
Jan 26, 2009 | Washing Machines
Balance
No washer will stay balanced.
but if the feet on the bottom are not solid on the floor. or the rubber feet have degraded/hardened it will bang the washer side to side with all loads.
if you can lean on the washer while it is spinning and that quietens the noise then it needs the feet adjusted or replaced.
Jan 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
General Electric WCVH6800J Front Load Washer Logo
408 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a General Washing Machine Expert? Answer questions, earn points and help others
