Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Have a sub Zero side by side. Its 22 years aold. both Freezer and Fridge motor things in the the top unit have been replace. It is ONLY serviced by a Sub Zero expert. Black mildew is appearing in the crevices, on the edges of the crisper units and on the plastic lids of certain items . its doesn't seem to be toxic (?) or Very pervasive---its just obnoxiou & clearly not normal. And a pain to clean. What is the problem & how can I cure it. Iwash this thing about once a month thoroughly with a bleach solution. HELP!
  • awe0171 Apr 06, 2011
    Thank you Keith,
    The door seal, upon examination, IS showing its age----tho' not from chlorine bleach which I would never use on gaskets---new gasket on order from our wonderful Subzero repair person.
    Thanks again.
    Guru:
  • 262 Answers
My guess without actually seeing it myself would be there is a leak of either water coming from somewhere or the door seal is bad allowing a moisture to build up.
If you are using a bleach solution on the door gasket.....this just may be the reason the seals are bad. Never use chlorine/bleach on any gasket or seal. It will ruin them.
You will need to check the gaskets on the doors. First ensure the doors are aligned properly.
The tops of the refrigerator doors should be even.
Now check for gaps or gasket rips/tears. The surface of which the door gasket seals must not having any gaps in it....check the entire diameter of the doors including the freezer door. You can use a mirror to check...it will make your job a bit easier.
Next ensure you do not have any water in either refrigerator section.
Please post results.
Keith
Posted on Apr 03, 2011
  • Keith Drake
    Keith Drake Apr 06, 2011
    Unit is 22 years old....nice to see someone getting their money's worth.
    Glad I could help.
    Best Regards....
    Keith
Freezer not working/but fan is running
The freezer side may be icing up. Soon enough the fridge side may have problems, too. Love those Sub-Zeros, but if the defrost timer fails, it will ice up. Defrost timer is up top. A generic one will do.
Nov 25, 2013 | Sub-Zero 642
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 611/O not cooling
sorry but i do not have experience with hte sub-zero product line, I can reccomend to you thought that it is a very expensive piecce, and replacing it ( with another sub-zero) may prove to be a more costly option then the repair, Generally a Qualified subzeroe technician, (at least inmy area) is strictly a SubZero, specialist, so although you may pay a premium for the service it will be backed by the manufacture, and only 6-7 years old i cant imagine a problem that would justify replacing the unit.Althougth Im a Do-it-your self advocate, there are somethings that are generally best to leave to a professional opinion. This would be my reccomendation
Jan 17, 2009 | Sub-Zero 611 / O Bottom Freezer...
My Sub-Zero 611/O is not cooling enough. The temp is 0 in the freezer and 46 in the fridge. I vacuumed very well the condenser. I can't tell which compressor is running. There are two, one larger than the...
More than likely the fan inside the back of the unit freezer compartment is not working and causing the freezer to freeze up.need to pull pannel off inside back of freezer and replace fan
Jan 14, 2009 | Sub-Zero 611 / O Bottom Freezer...
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 511 Freon Leak
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub-Zero not cooling properly
found leak at evaporator, made a video how to replace it on Sub Zero Vacuum Condenser Light stayed on
Jun 16, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
133 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
